Trying to upgrade 11.5.30 Update #47 to 12.0.18. Searched the KB and Forums & haven't found anything similar. Error is Exception: Failed to solve dependencies: - excerpt follows below (full installer log attached). All requirements are met or exceeded. Any ideas?
Traceback (most recent call last):
File "/usr/local/psa/bin/yum_install", line 225, in <module>
main()
File "/usr/local/psa/bin/yum_install", line 211, in main
inst, rem = installer.resolve(to_install, opts.remove, opts.tries)
File "/usr/local/psa/bin/yum_install", line 145, in resolve
raise Exception("Failed to solve dependencies:\n" + '\n'.join(msgs))
psa-php5-configurator-1.6.3-cos6.build1200140526.11.x86_64 requires php
plesk-core-12.0.18-cos6.build1200140606.15.x86_64 requires mysql-server >= 5.0.60
psa-proftpd-1.3.5-cos6.build1200140529.18.x86_64 requires xinetd
psa-spamassassin-12.0.18-cos6.build1200140606.15.x86_64 requires spamassassin >= 3.0.0
psa-phpmyadmin-4.2.0-cos6.build1200140528.14.noarch requires httpd
psa-mod_aclr2-14033111-9e86c2f.x86_64 requires httpd
plesk-core-12.0.18-cos6.build1200140606.15.x86_64 requires vixie-cron
plesk-web-hosting-12.0.18-cos6.build1200140606.15.x86_64 requires mod_ssl
psa-mailman-configurator-12.0.18-cos6.build1200140606.15.x86_64 requires mailman >= 2.1
psa-mod_sysenv-0.1-14033112.x86_64 requires httpd
psa-phppgadmin-5.1-cos6.build1200140423.17.noarch requires httpd
sw-cp-server-2.0.5-201405151701.centos6.x86_64 requires openssl >= 1.0.1
plesk-core-12.0.18-cos6.build1200140606.15.x86_64 requires ntp
plesk-web-hosting-12.0.18-cos6.build1200140606.15.x86_64 requires httpd
3sa-qmail-1.03-cos6.build1200140526.11.x86_64 requires inetd
plesk-core-12.0.18-cos6.build1200140606.15.x86_64 requires openssh-clients
psa-mod_fcgid-2.3.9-14033111.x86_64 requires httpd
psa-php5-configurator-1.6.3-cos6.build1200140526.11.x86_64 requires httpd
awstats-7.3-14050621.parallels.noarch requires httpd
pp12.0.18-bootstrapper-12.0.18-cos6.build1200140617.18.x86_64 requires mysql-server >= 5.0.60
psa-phpfpm-configurator-1.0.0-cos6.build1200140526.11.x86_64 requires php-fpm >= 5.3.3-23
psa-mod_rpaf-0.6-14033112.x86_64 requires httpd
Error: The Yum utility failed to install the required packages.
Attention! Your software might be inoperable.
Please, contact product technical support.
main()
