Problems with GD Lib
T
TomKra
Why does my Scripts with GD Lib functions not work. I think in PHP 4.3.4 is the GD 2 Lib inctuded ??
Any hints for me to use GD Lib on Suse 9.1 with Plesk ?
Tom
GD support isnt compiled into php in the standard installation of a suse 9.1 and plesk environment.
Fastest way you can get it, open yast and install your needed packages...
hope this heped you a bit...
