Problems with half solutions
W
welch
Ive been having some problems with my install and usage of plesk and am seeking some help.
When i first installed plesk 6.5 everything seemed ok. However.. had problems with Perldesk working in the cgi-bin. Basically... would not work.. i had to take some time to re-configure IIS to accept .cgi. Then.. my webmail wouldn't work. It would print the PHP code itself instead of showing the script. Then... all the FTP accounts disappeared. YES disappeared
One thing...
One thing I have found is.... NEVER uninstall then reinstall Plesk... If you can't fix your problems without doing an uninstall.... Wipe the server and reinstall everything fresh...
I learned that lesson the hard way.
Anjari
