Issue Recently i tried to update my plesk obsidain 18.0.63 to 18.0.64 then it shows following errors. kindly help me to solve this issue i am using centos 7
Sajeev kumar
CentOS Linux 7.9
Version 18.0.63 Update #4
This is the error message I got when I tried to update my Plesk obsidian 18.0.63 running on CentOS Linux 7.9.2009 (Core
to 18.0.64 then I got this message kindly help me to solve this issue
Enabled repositories check
http://asi-fs-n.contabo.net/centos/7/os/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
Trying other mirror.
To address this issue please refer to the below wiki article
https://wiki.centos.org/yum-errors
If above article doesn't help to resolve this issue please use https://bugs.centos.org/.
https://dlm.mariadb.com/repo/maxscale/latest/yum/rhel/7/x86_64/repodata/repomd.xml: [Errno 14] HTTPS Error 404 - Not Found
http://asi-fs-n.contabo.net/centos/7/updates/x86_64/repodata/repomd.xml: [Errno 14] HTTP Error 404 - Not Found
Unable to create yum cache for 'base' OS repository.
Make sure the repository is available, otherwise either disable it or fix its configuration, then try again.
Unable to create yum cache for 'updates' OS repository.
Looks like you're trying to add maxscale which does not support CentOS or RHEL 7. You can try downloading the mariadb repo setup for the specific version of mariadb of what you currently have and see if that works for that specific issue
As for the the other one, looks like you might being using Contabo for your hosting? If so, it's more likely that either that address does not exist any more or there's changes happening at the moment. In either case, you could always try changing the repos back to using just CentOS's repos instead of the hoster provided ones. You can refer to How to Correct Yum Baseurl Issues on CentOS 7 for help on that one.
In all honestly, though, considering CentOS is basically dead and more applications is starting to drop support for it I'd suggest attempting to convert your CentOS 7 installation to AlmaLinux 8 via the conversation script found at GitHub - plesk/centos2alma: CentOS 7 to AlmaLinux 8 conversion tool or spin up a new server, install the latest version of Plesk and use the Migration manager to migrate the sites over.
Whatever option you choose, make sure you have a good backup and/or snapshot in an event anything goes wrong so you can quicky roll back.
