Forwarded to devs rpm scriptlet problem: /etc/httpd/conf.d/security2.conf.rpmsave not actually saved
danami
Silver Pleskian
Username: danami
TITLE
PRODUCT, VERSION, OPERATING SYSTEM, ARCHITECTURE
roduct version: Plesk Obsidian 18.0.33.0
OS version: CentOS 8.3.2011 x86_64
Build date: 2021/01/23 00:00
Revision: db5d37f7d2a3360673aa3cba5d73bdda02aed535
PROBLEM DESCRIPTION
Upgrading to 18.0.33.0 replaces the /etc/httpd/conf.d/security2.conf file without actually creating the /etc/httpd/conf.d/security2.conf.rpmsave file.
During the Plesk upgrade I can see this:
Code:
Updating: plesk-modsecurity-configurator-18.0-2.centos.7+p18.0.33.0+t210122.1058.noarch [49/108]
warning: /etc/httpd/conf.d/security2.conf saved as /etc/httpd/conf.d/security2.conf.rpmsave
After the installer completes:
Code:
cat /etc/httpd/conf.d/security2.conf.rpmsave
cat: /etc/httpd/conf.d/security2.conf.rpmsave: No such file or directory
STEPS TO REPRODUCE
Run /usr/local/psa/admin/bin/autoinstaller to upgrade to 18.0.33.0 and you will see any of your customizations in /etc/httpd/conf.d/security2.conf get wiped out because the /etc/httpd/conf.d/security2.conf.rpmsave is not created properly.
ACTUAL RESULT
The /etc/httpd/conf.d/security2.conf.rpmsave is not created properly.
EXPECTED RESULT
If the /etc/httpd/conf.d/security2.conf file is to be replaced then the original file should be copied to /etc/httpd/conf.d/security2.conf.rpmsave.
ANY ADDITIONAL INFORMATION
YOUR EXPECTATIONS FROM PLESK SERVICE TEAM
Confirm bug
From developer:
The bug is confirmed as PPPM-12724.
But I need to note that we don't expect the use of this file for ModSecurity customization by customers. To make customization customer can use Plesk web interface: "Tools & Settings" -> "Web Application Firewall (ModSecurity) -> "Settings" -> "Custom directives".
You should note that this still isn't fixed in 18.0.33.1 and it's even worse than that. Upgrading to 18.0.33.1 will reset security2.conf and disable modsecurity completely even though it looks turned on in the Plesk interface (notice how the modsecurity module is commented out):
Looking at: /etc/httpd/conf.d/security2.conf after the upgrade
Code:
#LoadModule security2_module modules/mod_security2.so
<IfModule security2_module>
        SecDataDir /var/lib/mod_security
        IncludeOptional "/etc/httpd/conf/modsecurity.d/*.conf"
</IfModule>
