- OS: CentOS Linux 7.4.1708 (Core)
- Product: Plesk Onyx 17.5.3 Update #44
There are warnings on some of my domains when running this command: plesk repair fs -vhosts
For example:
Code:
There are files or directories with suspicious permissions in the
root directory of the domain 'mysite.com' ........................ [WARNING]
To see more details, run the command in the verbose mode: plesk repair fs -verbose
Error messages: 0; Warnings: 1; Errors resolved: 0
The issue I am experiencing is that plesk repair does not ask to repair the permissions.
After researching and finding this article: Plesk Repair Utility
I proceeded to run this command which is supposed to fix the permissions without asking and automatically, being under the impression that it will resolve the issue but it simply gave the warning again without fixing the permissions:
Code:
plesk repair fs -y mysite.com
Please, can someone tell me how to troubleshoot this and fix the permissions with the Plesk repair utility?
Also, when running the repair all command, it does prompt to fix certain issues such as configuration etc. and when I type Y, it states [ok]. But when I run the same command repair all, it still asks to repair the same issues such as configurations, should they have not been solved already moments before when I agreed for the misconfigurations to be fixed?
Thanks in advance.
