• Dear Pleskians! The Plesk Forum will be undergoing scheduled maintenance on Monday, 7th of July, at 9:00 AM UTC. The expected maintenance window is 2 hours.
    Thank you in advance for your patience and understanding on the matter.
Setting Up Virtuozzo Hardware Node In Plesk Billing?? Help Me!!
  • Thread starter lightning-torrents
  • Start date
L
lightning-torrents
Ok So I Have Been At This For Three Days...Rang Parallels And Still Got Not Answer,
I Have Installed Plesk Billing On A VPS (Hosted On A Virtuozzo Server) With Plesk Installed It Requires The Settings Below:-
Server Name:
Enabled: Yes/ No(Radio Button)
Virtuozzo Username:
Virtuozzo Password:
Virtuozzo URL:
Port Number:
The Settings I Have Entered Are:-
Server Name: Company Name - Server 1
Enabled: Yes
Virtuozzo Username: Root
Virtuozzo Password: MYROOTPASSWORD
Virtuozzo URL: ***.***.***.***
Port Number: 4433
For The Virtuozzo URL: I Have Also Tried A Web Address
Also For The Port I Have Also Tried 4643, 8443, 80
It Wont Even Retrive The Server Load
However The Plesk Addin Works Fine With Similar Settings, And Before I Am Asked The IP And Address I Am Using Is Pointing At The Virtuozzo Hardware Node
Thank You For Any Help You May Be Able To Give Me
It Seems The Plesk 8.6 Billing Center Dosent Quite Work :S, I upgraded To Plesk 9 And the Plesk 9 billing Center And It Has Worked Completly But The Center Is A Pain In The *** To Setup But Finally Got There :)
