• Plesk Uservoice will be deprecated by October. Moving forward, all product feature requests and improvement suggestions will be managed through our new platform Plesk Productboard.
    To continue sharing your ideas and feedback, please visit features.plesk.com
[Solved] help required - change nginx port
Imad S
Hey,
I need help in changing the nginx port. I've followed various threads and have created a custom nginxDomainVirtualHost.php file at: /usr/local/psa/admin/conf/templates/custom/domain, while the website indeed moves to the port I have set, a second nginx thread starts at port 80 and takes over in it's place.
I need to put varnish at port 80 and cannot do so until all services relinquish control on port 80.
Help please.
Solved!
Followed clues here:
http://download1.parallels.com/Ples...nistration-guide/index.htm?fileName=68800.htm
some here:
http://talk.plesk.com/threads/step-...and-integrate-varnish-with-plesk-12-x.310544/
Turn's out to be able to change the nginx port to a non-standard port you need to edit 6 files
  • nginx.php
  • nginxDomainForwarding.php
  • nginxDomainForwardingIpDefault.php
  • nginxDomainVhost.php
  • nginxDomainVhostIpDefault.php
  • nginxWebmail.php
For the time being i disabled SSL support for my test domain as I didn't need it. The line you need to look for the in above files is:
Code:
$VAR->server->nginx->httpPort
So the line would finally become from this:
Code:
<?php echo $VAR->includeTemplate('server/nginxVhosts.php', array(
    'ssl' => false,
    'frontendPort' => $VAR->server->nginx->httpPort,
    'backendPort' => $VAR->server->webserver->httpPort,
to this:
Code:
    'ssl' => false,
    'frontendPort' => "8888",
To get this to work you'll need to create a custom directory at: /usr/local/psa/admin/conf/templates
and copy the files over from the root of /usr/local/psa/admin/conf/templates/default
Hope this helps someone.
