SQL Problem
C
cosmick
Say user one tried to create a database naked phpnuke
then client 2 totally differnt account tries to creat a databse called phpnuke, the system blow errors stating that database already exists. This is a problem because they are2 totally different accounts and this should not be happening because peopel do use the same names for thigns. Can someone shed some insisght on ow to fix this. Thanks
Heh... There are two different accouns ;)
BUT ONE MYSQL SERVER ;))
And as sequence it prevents to create two databases with the same names.
I see
Ok then then what do others do meaning. You know when you install phpnuke it always has a defualt database name and a lot of people just stick with that. So if I have serveral customers trying it for the first time I dont want to have to advise them to change the defualt databse name. I know I didnt my first time running nuke. So how does everyone else do it. I mean even if there were 2 SQL servers that still wouldnt be enough. So what are my options.
