Strange open_basedir restriction problem
C
chrisroane
I have been trying to figure out this problem for several hours now without any luck.
Basically I have all of my php included files put into the cgi-bin directory so that they can't be loaded in the browser. Things work without a problem when I include those php files anywhere in the httpdocs folder, except when I try to access them on the secure certificate (https://).
For this domain, I have this option checked, so that I don't have to have two sets of files:
"Use a single directory for housing SSL and non-SSL content"
This is in my vhost.conf file:
<Directory "/home/httpd/vhosts/WEBSITE/httpdocs">
php_admin_value open_basedir none
</Directory>
This is in my vhost_sll.conf file:
<Directory "/home/httpd/vhosts/WEBSITE/httpsdocs">
</Directory>
This is the error it gives me:
Warning: main(): open_basedir restriction in effect. File(/home/httpd/vhosts/WEBSITE/cgi-bin/include/listing_process.inc) is not within the allowed path(s): (/home/httpd/vhosts/WEBSITE/httpdocs:/tmp) in /home/httpd/vhosts/WEBSITE/httpdocs/site/listings/test_new_listing.php on line 2
Warning: main(/home/httpd/vhosts/WEBSITE/cgi-bin/include/listing_process.inc): failed to open stream: Operation not permitted in /home/httpd/vhosts/WEBSITE/httpdocs/site/listings/test_new_listing.php on line 2
Fatal error: main(): Failed opening required '/home/httpd/vhosts/WEBSITE/cgi-bin/include/listing_process.inc' (include_path='.:/usr/share/pear') in /home/httpd/vhosts/WEBSITE/httpdocs/site/listings/test_new_listing.php on line 2
That error ONLY comes up when I try to access the (https://) version of the site. It loads fine when I go to the (http://) version of the site. I've read many posts on open_basedir problems, but none that describe this problem.
Any help would be highly appreciated.
The name of your vhost file should be: vhost_ssl.conf - you seem to have a spelling error.
Also remember to run a /path_to_psa/admin/bin/websrvmng --vhost-name=<the_domain> and restart Apache.
Yeah, that was a mistake in the post. The file name is vhost_ssl.conf . I just typed it wrong in the post.
"Also remember to run a /path_to_psa/admin/bin/websrvmng --vhost-name=<the_domain> and restart Apache."
Every time I made a change to the vhost files, I did that and restarted apache.
This problem is frustrating. Maybe I can't have the option ""Use a single directory for housing SSL and non-SSL content" and have access to the directory I want to access, without having two copies of the files?
turn off safe mode as well.
php_admin_value safe_mode 0
That's what I had to do to get that to work properly for a domain situation just like yours.
You can mimick the setting
easy enough.
cd /path/to/DOMAIN
mv httpsdocs httpsdocs.old
ln -s httpdocs httpsdocs
chown -h USERNAME:psaserv httpsdocs
Try that with your normal setup - personally i would not recommend turning safemode off unless its the very last choice.
Although personally i would put your includes in a directory in httpdocs and simply stick a password on the directory - they can then be accessed via the filsystem but http accesses will be requested to supply authentication.
