DarkKikies
Basic Pleskian
Hello,
Recently I happened to receive numerous emails from my plesk server with this content:
can not figure out how to solve. Anyway the vps is online and running all domains.
happen occur randomly, I get emails also 20 below..
Subject:
Cron <root@*****> /opt/psa/admin/bin/php -c '/opt/psa/admin/conf/php.ini' -dauto_prepend_file=sdk.php '/opt/psa/admin/plib/modules/dropbox-backup/scripts/plesk-task-manager.php'
[2017-02-01 08:24:01] ERR [panel] SQLSTATE[HY000] [2002] Cannot allocate memory:
0: /opt/psa/admin/externals/Zend/Db/Adapter/Pdo/Abstract.php:144
Zend_Db_Adapter_Pdo_Abstract->_connect()
1: /opt/psa/admin/externals/Zend/Db/Adapter/Pdo/Mysql.php:111
Zend_Db_Adapter_Pdo_Mysql->_connect()
2: /opt/psa/admin/externals/Zend/Db/Adapter/Abstract.php:460
Zend_Db_Adapter_Abstract->query(string 'SET sql_mode = ''', array)
3: /opt/psa/admin/externals/Zend/Db/Adapter/Pdo/Abstract.php:238
Zend_Db_Adapter_Pdo_Abstract->query(string 'SET sql_mode = ''', array)
4: /opt/psa/admin/plib/Db/Adapter/Pdo/Mysql.php:30
Db_Adapter_Pdo_Mysql->query(string 'SET sql_mode = ''')
5: /opt/psa/admin/plib/CommonPanel/Application/Abstract.php:90
CommonPanel_Application_Abstract::initDbAdapter()
6: /opt/psa/admin/plib/Session/Helper.php:165
Plesk\Session\Helper::initStorage()
7: /opt/psa/admin/plib/CommonPanel/Application/Abstract.php:36
CommonPanel_Application_Abstract->run()
8: /opt/psa/admin/plib/CommonPanel/Application/Abstract.php:18
CommonPanel_Application_Abstract::init()
9: /opt/psa/admin/plib/pm/Bootstrap.php:16
pm_Bootstrap::init()
10: /opt/psa/admin/plib/sdk.php:12
ERROR: Zend_Db_Adapter_Exception: SQLSTATE[HY000] [2002] Cannot allocate memory (Abstract.php:144)
PHP Fatal error: Uncaught exception 'PDOException' with message 'SQLSTATE[HY000] [2002] Cannot allocate memory' in /opt/psa/admin/externals/Zend/Db/Adapter/Pdo/Abstract.php:129
Stack trace:
#0 /opt/psa/admin/externals/Zend/Db/Adapter/Pdo/Abstract.php(129): PDO->__construct('mysql:dbname=ps...', 'admin', '$AES-128-CBC$Fl...', Array)
#1 /opt/psa/admin/externals/Zend/Db/Adapter/Pdo/Mysql.php(111): Zend_Db_Adapter_Pdo_Abstract->_connect()
#2 /opt/psa/admin/externals/Zend/Db/Adapter/Abstract.php(460): Zend_Db_Adapter_Pdo_Mysql->_connect()
#3 /opt/psa/admin/externals/Zend/Db/Adapter/Pdo/Abstract.php(238): Zend_Db_Adapter_Abstract->query('select param, v...', Array)
#4 /opt/psa/admin/plib/Db/Adapter/Pdo/Mysql.php(30): Zend_Db_Adapter_Pdo_Abstract->query('select param, v...', Array)
#5 /opt/psa/admin/plib/db.php(36): Db_Adapter_Pdo_Mysql->query('select param, v...')
#6 /opt/psa/admin/plib/db.php(212): db_query('select param, v...', false)
#7 /opt/psa/admin/plib/Plesk/Mode.php(423): get_param('disable_provisi...')
#8 /opt/psa/admin/pl in /opt/psa/admin/externals/Zend/Db/Adapter/Pdo/Abstract.php on line 144
