Issue subdomain https problem
behinamb
In windows Plesk, When I create a new subdomain, this address automatically redirects to HTTPS...
I want to use HTTP for subdomain. in Hosting Settings I uncheck SSL/TLS support but the problem not solved...
How Can I remove force redirect to HTTPS from subdomains? and can see the address with HTTP...
Uhh, I don't have access to Plesk right now but in one of the settings (might be the SSL page) there is an "auto redirect to https" or something along those lines. If that's turned off it could Cloudflare or a similar service if you use that you'll need to turn off auto https or disable cloudflare for that subdomain.
