Tomcat problem
C
CesarV
The tomcat has stopped working. I tried to restart the service, but the following message appears in the status:
lock file found but no process running for pid 9455
I ran yum reinstall the packages java-1.4.2-gcj-compat-1.4.2.0-40jpp.115, java-1.6.0-openjdk-devel-1.6.0.0-1.7.b09.el5, java-1.6.0-openjdk-1.6.0, psa-tomcat-configurator-9.2.3-cos5.build92091016.19, tomcat5-jsp-2.0-api-5.5.23-0jpp.7.el5_3.2, tomcat5-admin-webapps-5.5.23-0jpp.7.el5_3.2, tomcat5-jasper-5.5.23-0jpp.7.el5_3.2, tomcat5-server-lib-5.5.23-0jpp.7.el5_3. 2, tomcat5-5.5.23-0jpp.7.el5_3.2, tomcat5-webapps-5.5.23-0jpp.7.el5_3.2, tomcat5-servlet-2.4-api-5.5.23-0jpp.7.el5_3.2 and tomcat5-common-lib-5.5.23-0jpp.7.el5_3.2
After trying to reinstall without success, I removed and re-installed packages using the command /usr/local/psa/admin/bin/autoinstall, but tomcat did not work.
The detail is that the /etc/rc.d/init.do script execution "tomcat5" disappeared.
The logs show the following:
Caused by: java.lang.ClassNotFoundException: java.io.IOException
at java.net.URLClassLoader $ 1.run (URLClassLoader.java: 217)
at java.security.AccessController.doPrivileged (Native Method)
at java.net.URLClassLoader.findClass (URLClassLoader.java: 205)
at java.lang.ClassLoader.loadClass (ClassLoader.java: 319)
at java.lang.ClassLoader.loadClass (ClassLoader.java: 264)
at java.lang.ClassLoader.loadClassInternal (ClassLoader.java: 332)
... 38 more
Using CATALINA_BASE: / usr/share/tomcat5
Using CATALINA_HOME: / usr/share/tomcat5
Using CATALINA_TMPDIR: / usr/share/tomcat5/temp
Using JRE_HOME:
Jan 18, 2010 10:25:14 PM org.apache.catalina.startup.Catalina stopServer
SEVERE: Catalina.stop:
java.net.ConnectException: Connection refused
java.net.PlainSocketImpl.socketConnect at (Native Method)
at java.net.AbstractPlainSocketImpl.doConnect (AbstractPlainSocketImpl.java: 310)
at java.net.AbstractPlainSocketImpl.connectToAddress (AbstractPlainSocketImpl.java: 176)
at java.net.AbstractPlainSocketImpl.connect (AbstractPlainSocketImpl.java: 163)
at java.net.SocksSocketImpl.connect (SocksSocketImpl.java: 381)
at java.net.Socket.connect (Socket.java: 537)
at java.net.Socket.connect (Socket.java: 487)
at java.net.Socket. <init> (Socket.java: 384)
at java.net.Socket. <init> (Socket.java: 198)
org.apache.catalina.startup.Catalina.stopServer at (Catalina.java: 395)
at sun.reflect.NativeMethodAccessorImpl.invoke0 (Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke (NativeMethodAccessorImpl.java: 57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke (DelegatingMethodAccessorImpl.java: 43)
at java.lang.reflect.Method.invoke (Method.java: 616)
org.apache.catalina.startup.Bootstrap.stopServer at (Bootstrap.java: 344)
at org.apache.catalina.startup.Bootstrap.main (Bootstrap.java: 435)
What should I do to solve the problem?
Thank you.
Yes IgorG, this is the version installed on my server, but Tomcat does not start. I tried to restart the service, but the following message appears in the status: lock file found but no process running for pid 9455
What can I do?
Try to kill all tomcat related processes and delete lock file. After that try to start Tomcat. Contact support team if it not help.
