URGENT !! proftpd Problem under Suse 9.1
M
MettyBirdy
Hello
I have the followed problem with plesk 7.5 Reloaded under SUSE 9.1. I hope that you can help me.
I have installed SUSE 9.1 as minimal System without anything. (APACHE, PHP etc.)
After that I have installed Plesk 7.5 with the SUSE 9.1 Autoinstaller.
After the installer has finished I configured Plesk. All is right. All my Domains will be ready for using. After that I have try to connect via ftp.
If get the following error:
server:~ # ftp
ftp> open
(to) domain.com
Connected to server.domainXXX.de.
421 Service not available, remote server has closed connection.
Ok after that I have checked it proftpd will be startet. If got these error.
server:~ # proftpd start
- getaddrinfo 'server' error: Name or service not known
- warning: unable to determine IP address of 'server'
- error: no valid servers configured
- Fatal: error processing configuration file '/etc/proftpd.conf'
server:~ #
So Ftp will be started but it doesnt work why ?
Ok normally proftpd will be startet by the xinet.d Daemon. So I habe also checked that the daemon will be startet. It was ready. I have checked it also by netstat.
Can anybody help me ??? It is really URGENT !!!!
Can nobody help me ???
It is very urgent !!!!
Thank you in advance
