    https://survey.webpros.com/
Using ImageMagick ... seems not possibile
S
scislaghi
Hi all,
i've read many posts about imagemagick. I've installed it on my RHEL 3 + PSA 7.5.4 to use serendipity blog system.
I've use rpm provided on www.pbone.net
ImageMagick-5.5.7.33-1.3_1.el3.at
But php pages are not able to run it. Is there some tips?
Thanks
Stefano
What happens when you run
convert -version
at the command line?
And have you tried installing from source? It is easy.
wget ftp://ftp.imagemagick.org/pub/ImageMagick/ImageMagick.tar.gz
tar -xvzf ImageMagick.tar.gz
cd ImageMagick-(the version you downloaded)
./configure
make
make install
And that's it! Try:
/usr/local/bin/convert -version
again to see if things have improved.
Note that I have no idea about how PHP talks to ImageMagic. However, there is an API called MagicWand -- this gets installed when you compile from source as above.
Also note that the RPM version you may (or may not) have installed already will remain in your system. You may want to remove it with rpm -e (name of the package) so that applications don't use the "old" version or get confused.
Faris.
