• Introducing WebPros Cloud - a fully managed infrastructure platform purpose-built to simplify the deployment of WebPros products !  WebPros Cloud enables you to easily deliver WebPros solutions — without the complexity of managing the infrastructure.
    Join the pilot program today!
  • Support for BIND DNS has been removed from Plesk for Windows due to security and maintenance risks.
    If a Plesk for Windows server is still using BIND, the upgrade to Plesk Obsidian 18.0.70 will be unavailable until the administrator switches the DNS server to Microsoft DNS.
Watchdog Module Install Problem
X
Xchido
I am trying to install my watchdog module from the control panel in plesk and the server just times out without installing it. These past days I have been making changes to the server because of some storage issues that I had. One of the things that I tried was uninstalling the watchdog module. Now that I have my site working I want to start turning on all the modules that I took out. After trying to install the watchdog module several times, I am still not able to get it done.
What should I be checking or changing to be able to install the watchdog module.
Any help will be greatly appreciated.
CPU GenuineIntel, Intel(R) Celeron(R) CPU 2.00GHz
Version psa v8.1.1_build81070423.15 os_FedoraCore 4
OS Linux 2.6.16-rc6-060427a
Here's an option for you. Use Plesk's autoinstaller from http://www.swsoft.com/en/download/plesk/products/ to do this from the shell. It's a very nice text-based wizard interface. Go through it once to uninstall Watchdog. Then go through it again to install Watchdog. Download the autoinstaller for the same version of Plesk that you are running. Otherwise, it could cause problems.
Thank you for your advice. I ended up just re-formating the server and start from scratch.
