Resolved Watchdog (System Monitoring) is missing
HI,
Thank you for your fast reply!
I don't find it.
Check what I get:
Hi gadalf,
"watchdog" is a Plesk component, which can be installed over the Plesk Control Panel ( => HOME > Updates and Upgrades > Add/Remove Components ):
... or you are able to install it over the command ( logged in as user "root" over SSH ):
Code:
plesk installer --select-product-id plesk --select-release-current --install-component watchdog
HI,
Thank you for your reply
I dont see it in updates and upgrades
Then I tried the second solution.
I run
"plesk installer --select-product-id plesk --select-release-current --install-component watchdog"
I get:
BUSY: Update operation was locked by another update process.
exit status 1
I have googled and got this solution:
Launching Plesk autoinstaller fails: Update operation was locked by another update process
I run:
# ps auxffww | grep autoinstaller
get:
root 18120 0.0 0.0 112648 964 pts/0 S+ 00:03 0:00 | \_ grep --color=auto autoinstaller
[root@****** ~]# strace -p $18120
strace: attach: ptrace(PTRACE_ATTACH, ...): No such process
Thank you in advance
Hi gadalf,
as you can see within YOUR image from your Plesk Control Panel, there is a "+" - sign in front of several menu items. If you click on such a "+" - sign, you will open the submenu of this menu item. ;)
This is YOUR current used command, to list possible processes => "ps auxffww | grep autoinstaller" ;)
I get:
exit status 1
This is absolute normal to see, if you didn't close your "webinstaller" - instance and you moved directly to your shell, in order to use a "plesk installer" - command. Only ONE "installer" - process is allowed and "webinstaller" - sessions are only automatically closed after 30 minutes of inactivity. ;)
"plesk installer --select-product-id plesk --select-release-current --install-component watchdog" worked ;)
Well It is very very wired Plesk lads
Couple of weeks a go I was installing PKLESK and I was actually able to install Watchdog
Now it is gone again (Screen Attached)
I did try to use the direct component installation : plesk installer --select-product-id plesk --select-release-current --install-component watchdog
and di not work too:
# plesk installer --select-product-id plesk --select-release-current --install-component watchdog
Downloading file products.inf3: 0%
Downloading file products.inf3: 100% was finished.
Downloading file pool/PSA_18.0.56_12883/release.inf3: 0%
Downloading file pool/PSA_18.0.56_12883/release.inf3: 100% was finished.
Downloading file pool/PSA_18.0.55_12738/release.inf3: 0%
Downloading file pool/PSA_18.0.55_12738/release.inf3: 100% was finished.
Downloading file pool/PSA_18.0.54_12607/release.inf3: 0%
Downloading file pool/PSA_18.0.54_12607/release.inf3: 100% was finished.
Downloading file pool/PSA_18.0.53_12045/release.inf3: 0%
Downloading file pool/PSA_18.0.53_12045/release.inf3: 100% was finished.
Downloading file pool/PSA_18.0.52_11753/release.inf3: 0%
Downloading file pool/PSA_18.0.52_11753/release.inf3: 100% was finished.
Downloading file pool/PSA_18.0.51_11495/release.inf3: 0%
Downloading file pool/PSA_18.0.51_11495/release.inf3: 100% was finished.
Downloading file pool/PSA_18.0.50_11079/release.inf3: 0%
Downloading file pool/PSA_18.0.50_11079/release.inf3: 100% was finished.
Downloading file plesk.inf3: 0%
Downloading file plesk.inf3: 100% was finished.
Downloading file sitebuilder.inf3: 0%
Downloading file sitebuilder.inf3: 100% was finished.
Downloading file pool/WPB_18.0.55_74/release.inf3: 0%
Downloading file pool/WPB_18.0.55_74/release.inf3: 100% was finished.
Downloading file pool/WPB_18.0.51_64/release.inf3: 0%
Downloading file pool/WPB_18.0.51_64/release.inf3: 100% was finished.
Downloading file PHP82_17/release.inf3: 0%
Downloading file PHP82_17/release.inf3: 100% was finished.
Downloading file php82.inf3: 0%
Downloading file php82.inf3: 100% was finished.
Downloading file PHP81_17/release.inf3: 0%
Downloading file PHP81_17/release.inf3: 100% was finished.
Downloading file php81.inf3: 0%
Downloading file php81.inf3: 100% was finished.
Downloading file PHP80_17/release.inf3: 0%
Downloading file PHP80_17/release.inf3: 100% was finished.
Downloading file php80.inf3: 0%
Downloading file php80.inf3: 100% was finished.
Downloading file php72.inf3: 0%
Downloading file php72.inf3: 100% was finished.
Downloading file PHP74_17/release.inf3: 0%
Downloading file PHP74_17/release.inf3: 100% was finished.
Downloading file php74.inf3: 0%
Downloading file php74.inf3: 100% was finished.
Downloading file php73.inf3: 0%
Downloading file php73.inf3: 100% was finished.
Downloading file php71.inf3: 0%
Downloading file php71.inf3: 100% was finished.
Downloading file setemplates.inf3: 0%
Downloading file setemplates.inf3: 100% was finished.
Downloading file pp-sitebuilder.inf3: 0%
Downloading file pp-sitebuilder.inf3: 100% was finished.
Downloading file billing.inf3: 0%
Downloading file billing.inf3: 100% was finished.
Downloading file mysql.inf3: 0%
Downloading file mysql.inf3: 100% was finished.
Downloading file apache.inf3: 0%
Downloading file apache.inf3: 100% was finished.
Downloading file nginx.inf3: 0%
Downloading file nginx.inf3: 100% was finished.
Downloading file php70.inf3: 0%
Downloading file php70.inf3: 100% was finished.
Downloading file php56.inf3: 0%
Downloading file php56.inf3: 100% was finished.
Downloading file php55.inf3: 0%
Downloading file php55.inf3: 100% was finished.
Downloading file php54.inf3: 0%
Downloading file php54.inf3: 100% was finished.
Downloading file php53.inf3: 0%
Downloading file php53.inf3: 100% was finished.
Downloading file php52.inf3: 0%
Downloading file php52.inf3: 100% was finished.
Downloading file pmm.inf3: 0%
Downloading file pmm.inf3: 100% was finished.
Checking for installed packages...
Downloading file pool/PSA_18.0.56_12883/plesk-18.0.56-rhel9-x86_64.inf3: 0%
Downloading file pool/PSA_18.0.56_12883/plesk-18.0.56-rhel9-x86_64.inf3: 100% was finished.
Downloading Extensions Catalog feed...
Downloading file https://ext.plesk.com/api/v4/packages?platform=unix&version=18.0.56&ai-compatible: 0%
Downloading file PHP74_17/php74-rhel9-x86_64.inf3: 0%
Downloading file PHP74_17/php74-rhel9-x86_64.inf3: 100% was finished.
Downloading file PHP80_17/php80-rhel9-x86_64.inf3: 0%
Downloading file PHP80_17/php80-rhel9-x86_64.inf3: 100% was finished.
Downloading file PHP81_17/php81-rhel9-x86_64.inf3: 0%
Downloading file PHP81_17/php81-rhel9-x86_64.inf3: 100% was finished.
Downloading file PHP82_17/php82-rhel9-x86_64.inf3: 0%
Downloading file PHP82_17/php82-rhel9-x86_64.inf3: 100% was finished.
Downloading file pool/WPB_18.0.55_74/sitebuilder-18.0.55-rhall-all.inf3: 0%
Downloading file pool/WPB_18.0.55_74/sitebuilder-18.0.55-rhall-all.inf3: 100% was finished.
gpg-pubkey-914bdf7e-55c05220 Plesk Team <[email protected]> public key
gpg-pubkey-3228467c-613798eb Fedora (epel9) <[email protected]> public key
gpg-pubkey-fd431d51-4ae0493b Red Hat, Inc. (release key 2) <[email protected]> public key
gpg-pubkey-5a6340b3-6229229e Red Hat, Inc. (auxiliary key 3) <[email protected]> public key
Start downloading 1 files of unknown size and 0 delta RPMs
Download PLESK_18_0_56 extras 3089B [total 0/unknown B 1/1 files]
Download PHP 7.4 3081B [total 0/unknown B 1/1 files]
Download PHP 8.0 3080B [total 0/unknown B 1/1 files]
Download PHP 8.1 3081B [total 0/unknown B 1/1 files]
Download PHP 8.2 3081B [total 0/unknown B 1/1 files]
Detecting installed product components.
Download PLESK_18_0_56 dist 3090B [total 0/unknown B 1/1 files]
Download PLESK_18_0_56 thirdparty 3071B [total 0/unknown B 1/1 files]
Download PHP 8.0 thirdparty 3068B [total 0/unknown B 1/1 files]
Download PHP 8.1 thirdparty 3068B [total 0/unknown B 1/1 files]
Download PHP 8.2 thirdparty 3068B [total 0/unknown B 1/1 files]
You already have the latest version of product(s) and all the selected components installed. Installation will not continue.
Watchdog is only available in Plesk for Linux, and is not available on Red Hat Enterprise Linux 9, AlmaLinux 9, Debian 11, and Ubuntu 20.04 and later.
:) I'm really sorry to ask but, Redhat, Alma, Debian and Ubuntu are not linux distributions?
Watchdog is no longer available for the recent Linux distributions that Peter listed. It is still available for the older Linux versions.
If you need an auto restart function, have a look at this page:
Or install Monit yourself, which is the component that Watchdog is based on.
