Webradio using Airtime, vhost issue?
JeromeFA
Hello,
i'm runing a Kimsufi dedicated server, with ubuntu 12.04 lts + plesk 11.
On it, i have my domain which is declared (let's say www.mydomain.com), a sub-domain (radio.mydomain.com). Till here, no problem, everything is fine.
I also have a icecast server runing on it, which i can access by mydomain.com:8000 or radio.mydomain.com:800 , no probleim either.
But to feed icecast, i'm triyng to use Airtime. I installed it through ssh, and it creates a vhost (for apache2), linking a subdomain (let's say airtime.mydomain.com) to the real folder ( /usr/share/airtime/public ). But, as far as i understand it, Plesk "overides" apache, then it won't work.
I tried to create a vhost accepted by plesk (with a vhost.conf file in var/www/vhosts/mydomain.com/conf and then runing a ssh command : /usr/local/psa/admin/bin/websrvmng -av), but i only can do a vhost like www.mydomain.com/airtime , and even if now i can access to the page, i can't use it (because the redirection are not correct).
Airtime really need to be on the root of a domain (or subdomain).
So, here's my question : how can i create a subdomain (airtime.mydomain.com) that will point on the folder of airtime (/usr/share/airtime/public)
Thanks
Jerome
