When will SW fix open issues?
Discogalaxy
Since some weeks there are no new updates for Plesk 8.0.1 on Debian Sarge.
Open issues:
- Traffic and space isn't counting!
- Spamassassin isn't working as fine as with 7.5
- Watchdog isn't working:
Code:
Error occurred while building configuration file. For help, refer to technical support.
- Chaning passwort doesn't affekt some thinks like webalizer etc....
I read somewhere here that a fix for counting traffic and space will come "soon"...
So what SW?
I have found that most of the problem with spamassassin was just missing perl modules. If you look through your maillog it will tell you which ones. Install them and spamassassin should work much better. There was also a problem with the whitelist and I found the fix for that here on the forums. I believe you only had to delete the whitelist directory and it was recreated automatically.
