2 Servers same problem
B
Brian
I'm running 2 test servers, and both have Redhat 9 and Plesk 7.5.1 on them.
Problems on install;
Server 1
server001.domain.net
  1. Dr Web (Key not found! Plesk authorization failed: HTTP Request error [7]
  2. Error: Plesk software not running
  3. Httpd [FAILED]
  4. websrvmng: Service httpd failed to gracefully restart: Operation not permitted
    [/list=1]
    Server 2
    server002.domain.net
    3. Httpd [FAILED]
      [/list=1]
      Any help on this would be great, cant run tests and check things out if it does not work properly.
error_log
[warn] RSA server certificate CommonName (CN) 'plesk' does NOT match server name!
[warn] RSA server certificate ia a CA certificate. (Basic) constraints: CA == TRUE!
[alert] (22002) Name or service not known: mod_unique_id: unable to find IPv4 address of server002.domain.net. Configeration failed
I was getting similar errors when I changed my hostname to srv1.mydomain.com, when I changed it back to mydomain.com the errors disappeared. I'm not sure if this is why your server is giving you errors, but it might be worth looking at...
Apache can't resolve the name of your server to an IP.
Either you have to specify a different name in the httpd.conf, fix your /etc/hosts file to have the IP and name match up, or put the name of your server into a proper DNS record so it can resolve, or fix /etc/resolv.conf so another nameserver can resolve the name.
Hi guys,
I am having much the same problem. I get two of the same errors as above...
# (Key not found! Plesk authorization failed: HTTP Request error [7]
# Error: Plesk software not running
I have tried the solutions that were suggested but the error continues. Is this something that is critical? The server appears to be functioning normally and I am having no troubles otherwise... is this something thats going to sneak up on me and bite me in the ***?
Thanks,
Steve
Trend New Technologies
