• Introducing WebPros Cloud - a fully managed infrastructure platform purpose-built to simplify the deployment of WebPros products !  WebPros Cloud enables you to easily deliver WebPros solutions — without the complexity of managing the infrastructure.
    Join the pilot program today!
  • The Horde component is removed from Plesk Installer. We recommend switching to another webmail software supported in Plesk.
  • The BIND DNS server has already been deprecated and removed from Plesk for Windows.
    If a Plesk for Windows server is still using BIND, the upgrade to Plesk Obsidian 18.0.70 will be unavailable until the administrator switches the DNS server to Microsoft DNS. We strongly recommend transitioning to Microsoft DNS within the next 6 weeks, before the Plesk 18.0.70 release.
8.1.0 to 8.1.1 update problems - Please help
P
pstechnology
hi
I am trying to update my 1&1 Plesk 8.1.0 server to 8.1.1.
I go into the updater, select the minimal packages to install, confirm the installation, the I get the following notices on the update screen:
Information: Installation started. You will be notified of installation progress by e-mail
Information: Installation is in progress.
Error: Select the components to be installed
...and the screen goes back to the updater screen with the selected updates reselected again.
I get 2 autoinstaller reports by email. The first is a success report, the second a failure report. They say..:
Success Report:
Autoinstaller 3.1.2 (build at 2007-03-21 18:01) started at (timezone GMT) Fri Apr 6 12:14:00 2007 Command line args: /usr/local/psa/admin/bin/autoinstaller --enable-xml-output --source-type=plesk --target=/var/www/psa --select-release-id=PLESK_8_1_1 --notify-email=xxxxxxxxxxxxx --install-component=psa-autoinstaller --no-daemon
Try to find rcfile...
Autoinstaller rcfile not found.
Check hostname is sucessfull.
Opsys detected as: os_name=Linux os_vendor=FedoraCore version=4 arch=i686 environment= Final opsys (with overriding) is: os_name=Linux os_vendor=FedoraCore version=4 arch=i686 environment=
repository: Get brief packages info for all sources Checking for installed system packages...readSystemPackagesBrief: execute rpm -qa --queryformat 'F:system_installed_brief_%{NAME}-%{VERSION}-%{RELEASE}.rpm\nN:%{NAME}\nE:%{EPOCH}\nV:%{VERSION}\nL:%{RELEASE}\nA:%{ARCH}\nf:%{INSTALLTIME}\nB:%{BUILDTIME}\nX:\n'
done.
Download file products.inf3: 100% done.
Download file plesk.inf3: 29%..100% done.
Download file sitebuilder.inf3: 10%..100% done.
release PLESK_8_1_1 is actual
release SB_3_0_0 is actual
release SB_3_0_1 is actual
release SB_3_0_2 is actual
Select best build of PLESK_8_1_1 for current OS First fit build is current best: PSA_8.1.1/plesk-8.1.1-fc4-i386.inf3
Select best build: finally choised PSA_8.1.1/plesk-8.1.1-fc4-i386.inf3
Download file PSA_8.1.1/plesk-8.1.1-fc4-i386.inf3: 100% done.
repository: Get brief packages info for all sources Check for components installation status Component base: mode upgrade, installed=1174562606, available=1174628359 Component psa-autoinstaller: mode up2date, installed=1174478602, available=1174478602 Component asp: mode upgrade, installed=1164820136, available=1174562571 Component mailman: mode upgrade, installed=1164820137, available=1174562573 Component postgresql: mode up2date, installed=1148317978, available=1148317978 Component java: mode install, installed=0, available=1174562430 Component spamassassin: mode install, installed=0, available=1174562436 Component rblsmtpd: mode upgrade, installed=1164819979, available=1174562432 Component mod_python: mode up2date, installed=1109926542, available=1109926542 Component ruby: mode install, installed=0, available=1174562582 Component fcgi: mode install, installed=0, available=1160389821 Component vault: mode upgrade, installed=1165543400, available=1174877970 Component horde-comps: mode upgrade, installed=1164820109, available=1174562540 Component docs: mode up2date, installed=1174562530, available=1174562530 Component backup-ded: mode upgrade, installed=1167122182, available=1174562568 Component drweb: mode install, installed=0, available=1174562400 Component ppwse: mode install, installed=0, available=1174562555 Component api: mode upgrade, installed=1167122174, available=1174562422 Component sshterm: mode upgrade, installed=1164819919, available=1174562370 Component pmm: mode up2date, installed=1174562565, available=1174562565 Component psa-firewall: mode upgrade, installed=1164819976, available=1174562428 Component cs-gs: mode install, installed=0, available=1174562425 Component psa-vpn: mode install, installed=0, available=1174562524 Component battlefield: mode install, installed=0, available=1174562544 Component bf2: mode install, installed=0, available=1174562576 Component psa-fileserver: mode install, installed=0, available=1174562418 Component watchdog: mode upgrade, installed=1164820128, available=1174562562 Component sitebuilder: mode install, installed=0, available=1164691550 Component sb-publish: mode install, installed=0, available=1160554112 Component cf-support: mode install, installed=0, available=1174562578 Component atis: mode install, installed=0, available=1167889488 Component miva: mode install, installed=0, available=1174562585 Component de-DE-locale: mode install, installed=0, available=1174825695 Component ja-JP-locale: mode install, installed=0, available=1174825720 Component es-ES-locale: mode install, installed=0, available=1174825705 Component ru-RU-locale: mode install, installed=0, available=1174825741 Component fr-FR-locale: mode install, installed=0, available=1174825711 Component it-IT-locale: mode install, installed=0, available=1174825717 Component zh-CN-locale: mode install, installed=0, available=1174825750 Component zh-TW-locale: mode install, installed=0, available=1174825752 Check for components requires keyupdate No keyupdate need for component base Can't select component psa-autoinstaller: already installed There is no component(s) selected for install, exit.
Exit with OK status
Plesk autoinstaller.
I will post the Failure report in a reply.
Any ideas please? Thank you.
The Failure Report
The Failure Report
Autoinstaller 3.1.2 (build at 2007-03-21 18:01) started at (timezone GMT) Fri Apr 6 12:14:04 2007 Command line args: /usr/local/psa/admin/bin/autoinstaller --enable-xml-output --source-type=plesk --target=/var/www/psa --select-release-id=PLESK_8_1_1 --notify-email=xxxxxxxxxxxxxx --install-component=base --install-component=backup-ded --install-component=api --install-component=psa-firewall --install-component=watchdog
done.
Download file plesk.inf3: 100% done.
KeyUpdateChecker::doCheck: no components for check key update
repository: Get full packages info for all sources Download file build-8.1.1-fc4-i386.hdr.gz: 33%..85%..100% done.
Reading system installed packages...execute command for generate rpm cache in /tmp:
rpm -qa --queryformat 'F:system_installed_%{NAME}-%{VERSION}-%{RELEASE}.%{ARCH}.rpm\nN:%{NAME}\nE:%{EPOCH}\nV:%{VERSION}\nL:%{RELEASE}\nA:%{ARCH}\nf:%{INSTALLTIME}\nB:%{BUILDTIME}\n[R:%{REQUIRENAME} %{REQUIREFLAGS:depflags} %{REQUIREVERSION}\n][P:%{PROVIDENAME} %{PROVIDEFLAGS:depflags} %{PROVIDEVERSION}\n][P:%{FILENAMES}\nm:%{FILEMODES}\n5:%{FILEMD5S}%{FILELINKTOS}\n][C:%{CONFLICTNAME} %{CONFLICTFLAGS:depflags} %{CONFLICTVERSION}\n][O:%{OBSOLETENAME} %{OBSOLETEFLAGS:depflags} %{OBSOLETEVERSION}\n]X:\n' > /tmp/autoinstaller_system_packages.cache
read cache file
done.
Download file update-8.1.1-fc4-i386.hdr.gz: 19%..48%..79%..100% done.
Getting packages to installation list:
Get packages to installation from selected component base Get packages to installation from selected component backup-ded Get packages to installation from selected component api Get packages to installation from selected component psa-firewall Get packages to installation from selected component watchdog Resolve components
Warning: unresolved requires 'dummy-fedora-core-4' from dummy-selinux-openvz-1.0-2.noarch
Warning: unresolved requires 'vzdummyfc4' from dummy-selinux-vz-1.0-2.noarch
Warning: packages conflict by files detected: package python-2.4.1-2.i386
conflict with package python-devel-2.4.3-8.FC4.i386
both have file /usr/lib/python2.4/config/Makefile with different md5 sum.
Warning: packages conflict by files detected: package Sitebuilder-2.1.3-fc4.build060607.14.i386
conflict with package sitebuilder-3.0.2-all.build06112310.noarch
both have file /usr/local/sitebuilder/.build with different md5 sum.
Warning: packages conflict by files detected: package sitebuilder-3.0.2-all.build06112310.noarch
conflict with package Sitebuilder-2.1.3-fc4.build060607.14.i386
Check package set before installation
repository: download selected packages
Download file base/psa-hotfix2-8.1.1-1.noarch.rpm: skipped because of md5 checksum match.
Download file base/psa-imp-4.1.3-fc4.build81070322.16.noarch.rpm: skipped because of md5 checksum match.
Download file opt/modules/firewall/psa-firewall-1.0.1-fc4.build81070322.16.i586.rpm: skipped because of md5 checksum match.
Download file opt/modules/watchdog/psa-watchdog-2.0.2-fc4.build81070322.16.i586.rpm: skipped because of md5 checksum match.
Start packages installation
Warning: unresolved requires 'desktop-file-utils >= 0.9' from redhat-menus-3.8-1.noarch
prepareInstallStep: resolve results for package(s):
(s) system_installed_bash-3.0-31.i386.rpm
(s) system_installed_psa-8.1.1-fc4.build81070322.16.i586.rpm
Install package psa-hotfix2-8.1.1-1.noarch
error: Failed dependencies:
psa-hotfix2 = 8.1.0 is needed by (installed) psa-8.1.0-fc4.build81061129.22.i586
catch error with message: Error while execute command rpm -U /var/www/psa/PSA_8.1.1/dist-rpm-FedoraCore-4-i386/base/psa-hotfix2-8.1.1-1.noarch.rpm
Errors just before:
- Error while execute command rpm -U /var/www/psa/PSA_8.1.1/dist-rpm-FedoraCore-4-i386/base/psa-hotfix2-8.1.1-1.noarch.rpm
ERROR: Error while execute command rpm -U /var/www/psa/PSA_8.1.1/dist-rpm-FedoraCore-4-i386/base/psa-hotfix2-8.1.1-1.noarch.rpm
Errors just before:
Check SElinux status after error:
Exit with ERROR status
Hi. Maybe someone can help me with this.
I have tried a suggestion elsewhere on this forum to remove the autoinstaller. great. Did that, and redownloaded the autoinstaller from swsoft.
Now, when I run the autoinstaller, It downloads all the necessary packages, starts the installation, and fails immediately saying:
error :Failed Dependacies
It then goes on to say how other packages failed then aborts saying Installation failed.
Please help!
Thank you.
