L
lolpopl
i can access to webmail (horde or atmail), i have a list of error :
When i was on 9.3, i have elready this problem.
Do you know tjis problem?
Strict Standards: Assigning the return value of new by reference is deprecated in /usr/share/psa-pear/PEAR.php on line 563
Strict Standards: Assigning the return value of new by reference is deprecated in /usr/share/psa-pear/PEAR.php on line 566
Strict Standards: Assigning the return value of new by reference is deprecated in /usr/share/psa-pear/Log.php on line 147
Strict Standards: Assigning the return value of new by reference is deprecated in /usr/share/psa-horde/lib/Horde/Notification.php on line 64
Strict Standards: Assigning the return value of new by reference is deprecated in /usr/share/psa-horde/lib/Horde/Perms.php on line 455
Strict Standards: Assigning the return value of new by reference is deprecated in /usr/share/psa-horde/lib/Horde/Perms.php on line 462
Strict Standards: Non-static method Browser::singleton() should not be called statically in /usr/share/psa-horde/lib/core.php on line 51
Strict Standards: Non-static method String::lower() should not be called statically, assuming $this from incompatible context in /usr/share/psa-horde/lib/Horde/Browser.php on line 318
Strict Standards: Non-static method String::lower() should not be called statically, assuming $this from incompatible context in /usr/share/psa-horde/lib/Horde/Browser.php on line 323
Strict Standards: Non-static method String::lower() should not be called statically, assuming $this from incompatible context in /usr/share/psa-horde/lib/Horde/Browser.php on line 331
Strict Standards: Non-static method Util::nonInputVar() should not be called statically in /usr/share/psa-horde/imp/lib/base.php on line 34
Une erreur fatale s'est produite
Failed to import configuration file "/usr/share/psa-horde/imp/lib/../../config/conf.php": Strict Standards: Non-static method Horde::getTempDir() should not be called statically, assuming $this from incompatible context in /etc/psa-webmail/horde/horde/conf.php on line 81 Strict Standards: Non-static method Util::getTempDir() should not be called statically, assuming $this from incompatible context in /usr/share/psa-horde/lib/Horde.php on line 1219
Strict Standards: Non-static method Auth::getAuth() should not be called statically, assuming $this from incompatible context in /usr/share/psa-horde/lib/Horde/Registry.php on line 321
