I just got an alert of a website on a Plesk server crashing, I believe its on httpd with nginx as reverse proxy. Both these are down and giving the following errors when I try to restart them:
Im not aware of any changes made to the server but when I check yum history I could see that the system had run some actions.
Im also seeing some warnings about named in /var/log/messages, restarting that hasn't helped though
Code:
# service httpd restart
Stopping httpd: [ OK ]
Starting httpd: httpd: Syntax error on line 221 of /etc/httpd/conf/httpd.conf: Syntax error on line 5 of /etc/httpd/conf.d/zz010_psa_httpd.conf: Could not open configuration file /usr/local/psa/admin/conf/generated/13690461240.49964400_server.include: No such file or directory
[FAILED]
Code:
# service nginx restart
nginx: [warn] duplicate value "TLSv1" in /etc/nginx/conf.d/sslv3-disable.conf:1
nginx: [warn] duplicate value "TLSv1.1" in /etc/nginx/conf.d/sslv3-disable.conf:1
nginx: [warn] duplicate value "TLSv1.2" in /etc/nginx/conf.d/sslv3-disable.conf:1
nginx: [emerg] open() "/etc/nginx/plesk.conf.d/webmail.conf" failed (2: No such file or directory) in /etc/nginx/conf.d/zz010_psa_nginx.conf:6
nginx: configuration file /etc/nginx/nginx.conf test failed
Code:
Apr 17 01:02:46 redacted named[15437]: loading configuration from '/etc/named.conf'
Apr 17 01:02:46 redacted named[15437]: using default UDP/IPv4 port range: [1024, 65535]
Apr 17 01:02:46 redacted named[15437]: using default UDP/IPv6 port range: [1024, 65535]
Apr 17 01:02:46 redacted named[15437]: sizing zone task pool based on 4 zones
Apr 17 01:02:46 redacted named[15437]: Warning: 'empty-zones-enable/disable-empty-zone' not set: disabling RFC 1918 empty zones
Apr 17 01:02:46 redacted named[15437]: reloading configuration succeeded
Apr 17 01:02:46 redacted named[15437]: reloading zones succeeded
