aps problems
A
aafreddy
i'am havig many problems using asp and asp+access.
i receive a lot of error500 and i'm really confused.
Example, this page doesn't work
strPAGENAME = Request.ServerVariables("URL")
strPAGENAME = Left(strPAGENAME, Len(strPAGENAME) - 4)
strPAGENAME = strPAGENAME & "_" & ".asp"
Server.Execute(strPAGENAME)
Also i'm having problems (same 500 error)
'Create database connection
'Initialise the strMailingListAccessDB variable with the name and path to
the Access Database
strMailingListAccessDB = "mailing_list/mailing_list.mdb"
'Create a connection odject
Set adoMailingListCon = Server.CreateObject("ADODB.Connection")
Any help?
Tnx
If you email me I can email you to asp documents that you can post on your server that will give you all the paths, real and virtual. Usually this tend to be the problem and quite possible could be in your case.
Also, a patch is forthcoming that corrects many problems.
