Asp Problem...
T
Topaz
Hello,
We faced a problem with ASP sites that use ACCESS DATABASE (MDB)... We just purchased a licence of PLESK PLUS... And have sites with PHP and ASP... PHP sites work fine... There is no problem with that... But we have problems with ASP sites... exactly with those which use ACCESS DATABASE... I guess it is related to some permission or smth... But not sure how to solve it... Could you please help us with that problem? :confused:
The address is: www.hatiralarim.com
Could please anyone check the address and help us to solve the problem?
Hope to get an answer as soon as possible...
Thanks and Kind Regards,
You can search a solution for an error that you've receive at support.microsoft.com
I'm sure that you can find the answer on their web-site.
