Z
zettaweb
After I installed the update patch 070517.18 I got an error when I try to change my Plesk installation.
So, I can't add or remove elements of the Plesk.
I go to Control Panel > Add or Remove Programs > Plesk 8.1 for Windows > Change
Until there it's OK, but when I try to conclude the operation, the following error appears:
These files above are exactly the software that update patch 070517.18 has modified.
Does anyone have the same problem than me? Or... does anyone have any idea about how to solve this problem?
Thanks.
Checksums of the following files do not match:
C:\Program Files\SWsoft\Install\070326.13\ClientMySQL.msi
C:\Program Files\SWsoft\Install\070326.13\AWStats.msi
C:\Program Files\SWsoft\Install\070326.13\SpamAssassin.msi
C:\Program Files\SWsoft\Install\070326.13\Python.msi
C:\Program Files\SWsoft\Install\070326.13\AdminMySQL.msi
Thanks.
