Resolved Cloning into bare repository '/var/www/vhosts/rapidshoper.com/git/laravel_c3fdb1'... fatal: could not read Username for 'https:/
adhirat
Ubuntu
Plesk Obsidian Web Host Edition 18.0.57 Update #2
Hi Team,
I am trying to host a larval application in my domain.
I have added the SSH key in my github account and when I tried to Import, I am getting the following error.
Can you please advise how to fix this?
Hello.
According to your screenshot - you provide an HTTP address as a repository URL. But authorization by SSH Key works only with SSH cloning. So you should go to your GitHub repository, find Clone option and choose SSH. After that, you will get a URL, that looks like [email protected]:<user>/<repoName>.git. With this URL, you will be able to clone your repo using Laravel Toolkit.
Hello.
Thanks... It worked...
Hello.
in my case, what is the solution?
I hide/blur some data
Please double-check if the index.html file is indeed present in the document root of the domain name in question. If yes, please rename the file to something like index.html_old. If that doesn't sort it, please navigate to Domains > example.com > Apache & Nginx Settings. Under "Index files" choose the "Enter custom value" option and define the format of the index file you are using.
I followed those steps, Please check the attached screenshots. I have 2 paths (httpdoc & git), where should the website path be?, This is a new empty server where I'm doing the test, so some git files are in the httpdoc path and some in the git path
The index file should be under httpdocs (unless otherwise specified). Under the git folder should contain the repository data.
