Issue CloudLinux 10 / AlmaLinux 10 – Passenger and CageFS problem
sandros-
CloudLinux 10.2 / AlmaLinux 10.2 (Lavender Lion)
Plesk Obsidian 18.0.81 Update 3
we're having trouble with the old passenger-cagefs problem on CloudLinux 10.
OS: CloudLinux 10.2 / AlmaLinux 10.2 (Lavender Lion)
Plesk: 18.0.81
Passenger: 6.2.0.1
Passenger, Node.js and Ruby are installed (and have already been reinstalled).
We know this article:
https://support.plesk.com/hc/en-us/...-server-with-CloudLinux-OS-and-CageFS-enabled
Unfortunately, the passenger-cagefs package is no longer available for CloudLinux 10 / AlmaLinux 10.
It looks like Passenger creates temporary files in /tmp/passenger.spawn.*, but these files are not accessible from within CageFS.
We get errors like:
Cannot open /tmp/passenger.spawn.XXXX/envdump/user_info
Cannot open /tmp/passenger.spawn.XXXX/envdump/envvars
Cannot open .../args.json: No such file or directory
We also noticed that /etc/cagefs/cagefs.mp only contains /usr/share/passenger, and there doesn't seem to be any specific CageFS integration for Plesk's Passenger packages.
Before manually changing Passenger paths or CageFS mountpoints, we'd like to know if there's an official solution for CloudLinux 10.
Is this a known issue, or has anyone already found a working solution?
Thanks!
Your diagnosis matches the old problem: CageFS gives each user a private /tmp, so the passenger.spawn.* directory created outside the jail isn’t visible to the jailed app process. The envdump and args.json errors fit that.
What I’d do, in order of risk:
  1. Disable CageFS for the affected subscription user. Plesk’s own KB uses this as a fallback for similar CageFS conflicts (the .NET article, for example). The command is cagefsctl --disable followed by the system user name. It costs you isolation for that user, but it changes nothing else.
  2. Ask the vendors directly. Check whether CloudLinux ships the package in its CL10 repos (yum search passenger-cagefs), and open a ticket with CloudLinux and Plesk. The package seems to be dropped or not yet ported, and only they can say which.
  3. Manual workaround. Put Passenger’s temp or instance directory on a path outside /tmp and add it to /etc/cagefs/cagefs.mp, then run cagefsctl --remount-all. That is roughly what passenger-cagefs did, but I haven’t verified the exact settings for Plesk’s Passenger on CL10, so test it on a non-production user first.
Regards
Tessa
