- Server operating system version
- AlmaLinux 8.9
- Plesk version and microupdate number
- 18.0.65
Hi, I have two servers with AlmaLinux 8.9
Plesk 18.0.65
PHP 8.3
2x NextCloud 28 no problems.
1x NextCloud 29 no problems.
1x NextCloud 30 background tasks do not work!
I put the cronjobs directly in Plesk and they run every 5 minutes without errors.
However, with NextCloud 30, I receive the message that the jobs do not run in its management settings.
In the NextCloud Forum I am not the only one with the problem under Plesk.
However, since no one there has an idea, I ask here, because it is probably connected with Plesk.
I hope that someone has an idea here.
Thank you
Plesk 18.0.65
PHP 8.3
Cron Jobs not running accoring to NC, after upgrade to NC30/ Hub9
Then check your logs, if the cronjob is really run. And if yes, try to log the output, perhaps it logs an error (even though it should be similar to what you do when you manually run the script on the shell as this user).
help.nextcloud.com
Thank you
