Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The APS Catalog has been deprecated and removed from all Plesk Obsidian versions. Applications already installed from the APS Catalog will continue working. However, Plesk will no longer provide support for APS applications.
Please be aware: with the Plesk Obsidian 18.0.78 release, the support for the ngx_pagespeed.so module will be deprecated and removed from the sw-nginx package.
I am having a problem setting the default index page. After I had Plesk upgraded to 7.5 it goes to index.php as a default, but I can't set it back to index.html .
Internal server is generated due to the permissions and ownership of the files, check that and also let me know if you are doing this for a specific domain or on server level
