• We value your experience with Plesk during 2024
    Plesk strives to perform even better in 2025. To help us improve further, please answer a few questions about your experience with Plesk Obsidian 2024.
    https://pt-research.typeform.com/to/AmZvSXkx
Issue Docker: WARNING: IPv4 forwarding is disabled. Networking will not work.
asanchez
CentOS Linux 7.9.2009
Plesk Obsidian v18.0.39
Docker version 1.5.0-209
I have several IPs blocked by Panel.ini
[ip]
blacklist = XXX.XXX.XXX.XXX
and these IPs are assigned by command line to different Docker containers:
docker run ... -p ...
As a result of having enabled IPv6 on my server following the indicated procedure here (https://support.plesk.com/hc/en-us/articles/115001918954-How-to-enable-IPv6-addresses-on-a-Plesk -server-), Plesk/CentOS has stopped correctly redirecting these IPs to the assigned containers, and Docker is giving me the error indicated in the title of this post.
If I run the following command in terminal, everything works correctly again:
echo 1 > /proc/sys/net/ipv4/ip_forward
Could this be considered a Plesk bug? Are you working on this?
Thanks!
Best regards,
