Double slash problem?
mparadis
Regular Pleskian
Do you have a ton of before-queue errors?
I see a lot of postings about these errors but no one has mentioned anything about the double slashes in there? This seems to have been installed by PSA at some point since I sure didn't make the change. I suspect others might be experiencing email problems because of this.
There is an error in the logs showing;
hook_dir = '/var/qmail//handlers/before-queue'
There is also a ton of the following which I suspect are related;
Apr 4 10:26:03 psa qmail: 1207322763.971446 warning: trouble injecting bounce message, will try later
Apr 4 10:26:06 psa qmail-queue-handlers[7038]: Handlers Filter before-queue for qmail started ...
Apr 4 10:26:06 psa qmail-queue-handlers[7038]: possible qmail-smtpd exited by timeout, reset connection or with "See http://pobox.com/~djb/docs/smtplf.html."
Does anyone know where this configuration might have the extra slash? I suspect at the end of qmail.
Mike
I'm the ONLY one having this problem??? How is that possible when all I do is update like everyone else?
There seems to be a double slash in Plesk's software, it's stopping much email from getting in and even out as far as I can tell.
In my logs, countless;
Coutnless
>handlers dir = '/var/qmail//handlers/before-queue/recipient
Would this double slash not be preventing the before-queue operation?
Mike
man qmail-log shows for example:trouble injecting bounce message...
qmail-send was unable to queue a bounce message, usually because the disk is full. It will try again later.
i have the double slash on all my servers in the log, but without any issue or impact...
Brujo
Brujo
Interesting, it's acting strangely, it's not accepting email from various domains and other things. It's constantly telling me that various domains have exceeded quota when they have not, things like that.
There is plenty of disk space too.
Thanks for the input.
Mike
did you check the quota, proper ownership/permissions of the related mailboxes/domains?
maybe also helpfull: http://kb.swsoft.com/en/944
http://forum.swsoft.com/showthread.php?t=51390
Brujo
Thanks for the lead, I've run this a few days ago to see if it would make any difference. I think the spam has gone down a little (if that's possible), the double slash is still there and these are very regular still;
Apr 9 10:11:22 psa qmail: 1207753882.251831 warning: trouble injecting bounce message, will try later
Apr 9 10:11:22 psa qmail-queue-handlers[21937]: Handlers Filter before-queue for qmail started ...
Apr 9 10:11:22 psa qmail-queue-handlers[21937]: possible qmail-smtpd exited by timeout, reset connection or with "See http://pobox.com/~djb/docs/smtplf.html."
I've read that it talks about a CR/LF problem and I've seen plenty of folks asking about it but have yet to find a solution, if there is one?
Mike
