• Plesk Uservoice will be deprecated by October. Moving forward, all product feature requests and improvement suggestions will be managed through our new platform Plesk Productboard.
    To continue sharing your ideas and feedback, please visit features.plesk.com
Firewall problem with ProFTPd
SlimDeluxe
Hi everyone.
I have enabled the plesk firewall component on my Plesk 12 / Ubuntu 14.04 machine.
Everything works except FTP. Upon connecting, it fails on the MLSD command.
Code:
Response:    200 Type set to I
Command:    PASV
Response:    227 Entering Passive Mode (x,x,x,x,174,229).
Command:    MLSD
Error:    Connection timed out
Error:    Failed to retrieve directory listing
If I release the "System policy for incoming traffic" to "Allow from everyone" it works. I have tried both secure and standard FTP connections, it does not make a difference.
Here's a screenshot of the rules.
The very same Firewall rules work just fine on my other Plesk 11 / Ubuntu machine.
I guess Plesk is not generating the correct rules. How can I determine which port should I open to make it work?
Regards,
Omer
following that article I added a rule with following:
Allow incoming from all on ports 20/tcp, 990/tcp
Nothing changed, still times out
When using passive ftp, the ftp server will change to another port then the usual and 20, 21, etc...
To allow passive connections in ftp you must do 2 things if you use a firewall:
- tell proftpd what ports to use for passive ftp
- open these ports in the firewall
To tell proftpd what ports to use you must add the following to /etc/proftpd.conf
PassivePorts 10000 10250
in the <Global> </Global> part of the configuration. I place mine just above </Global>, but that is up to you.
Then open these ports in the firewall.
What ports you use is up to you but be sure to use enough so there is room for everyone to connect.
Regards
Jan
