Question Frustrating Problem
LeeMc
Hi. I have Windows 2008 with Plesk Onyx (Version 17.0.17 Update #12) and I've been faced with a frustrating problem I can't seem to resolve.
I have a custom file extension (.srf) for a webpage which uses classic ASP. I've set up the script map handler mapping in IIS for .srf which calls the exact same executable as .asp. Any page which uses .asp runs perfectly fine but when I try to visit the .srf page, I'm getting an error...
"The requested content appears to be script and will not be served by the static file handler."
The .srf handler is identical to the .asp handler so I can't see why it isn't running. Am I failing to setup something within Plesk itself? Any ideas?
Thanks so much!
