• The BIND DNS server has already been deprecated and removed from Plesk for Windows.
    If a Plesk for Windows server is still using BIND, the upgrade to Plesk Obsidian 18.0.70 will be unavailable until the administrator switches the DNS server to Microsoft DNS. We strongly recommend transitioning to Microsoft DNS within the next 6 weeks, before the Plesk 18.0.70 release.
  • The Horde component is removed from Plesk Installer. We recommend switching to another webmail software supported in Plesk.
ftp backup problems by using active mode
C
Christian Roehl
I would like to configure Personal FTP Repository by using active ftp. But it seems that any ftp session is using passive instead of active mode:
220 ProFTPD 1.3.2 Server (server) [10.152.10.20]
USER user
331 Password required for cr_kunde.inter.net
PASS pw
230 User user logged in
PWD
257 "/" is the current directory
CWD /public_html
250 CWD command successful
PASV
227 Entering Passive Mode (10,152,10,20,204,198).
I found hotfix http://kb.odin.com/en/7059, but this doesn't help.
Any idea?
Could you please describe with more details how hotfix "doesn't help"?
initially i configuerd the backup an rceived the following log:
USER user
331 Password required for user
PASS pw
PWD
CWD /public_html
EPSV
229 Entering Extended Passive Mode (|||9464|)
PASV
227 Entering Passive Mode (10,152,10,20,202,189).
Then i was following the steps in the hotfix http://kb.odin.com/en/7059 and received:
USER user
PASS pw
PWD
CWD /public_html
PASV
Did you checked settings of personal FTP repository (Domains -> domain.tld -> Backup Manager -> Personal FTP Repository Settings) - "Use passive mode"?
Made the same config on a second host, centos 5.4 with plesk 9.3. FTP repository (Domains -> domain.tld -> Backup Manager -> Personal FTP Repository Settings) - "Use passive mode" is off (default) and I'm still not able to use the rep in active mode.
What is the reason of active mode using? Could you please describe? As far as I remember there were some problems with it.
The target plattform is able to provide ftp in active mode only. passive ftp is not available.
