Issue Remote Storage FTP(S) Issue
Gh()st
Ubuntu 22.04.3 LTS
Plesk Obsidian Version 18.0.58
I used to have this set up and working and for reasons that aren't important I disabled it since Oct. 2023. I am trying to set it back up again, using the exact same set up and configuration but now it is giving me issues.
When I check the settings as it suggests, I get this:
Code:
PS C:\Users\user> curl -v --ftp-pasv --ssl -k -u userName 'ftp://domain.tld//folderName/backups//'
Warning: --ssl is an insecure option, consider --ssl-reqd instead
Enter host password for user 'userName':
*   Trying IPAddress:21...
* Connected to domain.tld(IPAddress) port 21
< 220 (vsFTPd 3.0.5)
> AUTH SSL
< 530 Please login with USER and PASS.
> AUTH TLS
> USER userName
< 331 Please specify the password.
> PASS <passwordHere>
< 230 Login successful.
> PWD
< 257 "/" is the current directory
* Entry path is '/'
> CWD /
* ftp_perform ends with SECONDARY: 0
< 250 Directory successfully changed.
> CWD folderName
> CWD backups
> EPSV
* Connect data stream passively
< 229 Entering Extended Passive Mode (|||38734|)
* Connecting to IPAddress (IPAddress) port 38734
*   Trying IPAddress:38734...
* Connected to domain.tld (IPAddress) port 21
> TYPE A
< 200 Switching to ASCII mode.
> LIST
< 150 Here comes the directory listing.
* Maxdownload = -1
* Remembering we are in dir "/folderName/backups//"
< 226 Directory send OK.
* Connection #0 to host domain.tld left intact
I can also connect using FTP software like WinSCP. So I'm not sure what the issue is or how to fix it. I found somewhere that adding this line to the panel.ini file might help, it did not.
Code:
[pmm]
ftpForbidReuseConnection = 1
Same here:​
Server operating system version: OS Ubuntu 20.04.6 LTS
Plesk version and microupdate number: Plesk Obsidian Version 18.0.60 Update #1
And running the test:
Code:
curl --ftp-create-dirs -v --ftp-pasv -u user 'ftp://example.com/xxx/ftp-inbox/test-dir/'
Enter host password for user 'user':
*   Trying 181.47.64.115:21...
* TCP_NODELAY set
* Connected to example.com (ip-address) port 21 (#0)
> USER user
> PASS password
> PWD
< 257 "/home/user" is the current directory
* Entry path is '/home/user'
> CWD /
> CWD home
> CWD user
> CWD ftp-inbox
> CWD test-dir
> EPSV
< 229 Entering Extended Passive Mode (|||59885|)
*   Trying 181.47.64.115:59885...
* TCP_NODELAY set
* Connecting to ip-ftp-server (ip-ftp-server) port 59885
> TYPE A
> LIST
* Maxdownload = -1
* Remembering we are in dir "/home/user/ftp-inbox/test-dir/"
* Connection #0 to host sinclair.neuroglia.com.ar left intact
