Marquinhos
Hey,
we have a new dedicated server with Plesk 11.0.9 Update #53, updated on Juni 5, 2013 09:15 PM on a openSUSE 12.1
BUT !!!
We cannot connect per FTP to the server by using Filezilla. (Or Total Commander ...)
The FTP protocol goes till "MLSD" and stops/hangs then ...
Version of psa-proftpd
bugs.proftpd says there is a bug in version 1.3.4a
http://bugs.proftpd.org/show_bug.cgi?id=3734
What can we do?
Update to 1.3.4b or c ... how ?
We tried this per rpm, but get problems with dependecies.
Please help.
The server is NEW ... realy new (from 1und1 Germany), and no help from there ... GGGGRRRRRRRR.
Yes it's an "rootserver"
Here's the proftpd.conf
Yours
Markus as Marquinhois
- Ports are open
- telnet is working and OK
- FTP from another rootserver to the new one - is OK
- http://net2ftp.com/ ... works !
BUT !!!
Code:
XXXXX:/etc # proftpd -vv
XXXXXproftpd[11103]: mod_tls/2.4.3: compiled using OpenSSL version 'OpenSSL 1.0.0e 6 Sep 2011' headers, but linked to OpenSSL version 'OpenSSL 1.0.0k 5 Feb 2013' library
>>>> ProFTPD Version: 1.3.4a (maint)
Scoreboard Version: 01040003
Built: Wed Jun 6 2012 18:14:20 NOVT
Loaded modules:
mod_lang/0.9
mod_cap/1.1
mod_tls/2.4.3
mod_quotatab_file.c
mod_quotatab/1.3.0
mod_readme/1.0
mod_ratio/3.3
mod_auth_pam/1.1
mod_ident/1.0
mod_facts/0.3
mod_delay/0.7
mod_site.c
mod_log.c
mod_ls.c
mod_auth.c
mod_auth_file/0.9
mod_auth_unix.c
mod_xfer.c
mod_core.c
What can we do?
Code:
sXXXXXX:/etc # rpm -Uvh https://www6.atomicorp.com/channels/atomic/centos/6/x86_64/RPMS/psa-proftpd-1.3.4b-3.el6.art.x86_64.rpm
Retrieving https://www6.atomicorp.com/channels/atomic/centos/6/x86_64/RPMS/psa-proftpd-1.3.4b-3.el6.art.x86_64.rpm
warning: /var/tmp/rpm-tmp.OClac4: Header V3 DSA/SHA1 Signature, key ID 5ebd2744: NOKEY
error: Failed dependencies:
psa-proftpd-xinetd >= 1.3.4b-3.el6.art is needed by psa-proftpd-1.3.4b-3.el6.art.x86_64
sXXXXXX:/etc # rpm -Uvh https://www6.atomicorp.com/channels/atomic/centos/6/x86_64/RPMS/psa-proftpd-xinetd-1.3.4b-3.el6.art.x86_64.rpm
Retrieving https://www6.atomicorp.com/channels/atomic/centos/6/x86_64/RPMS/psa-proftpd-xinetd-1.3.4b-3.el6.art.x86_64.rpm
warning: /var/tmp/rpm-tmp.KgZFMn: Header V3 DSA/SHA1 Signature, key ID 5ebd2744: NOKEY
psa-proftpd = 1.3.4b-3.el6.art is needed by psa-proftpd-xinetd-1.3.4b-3.el6.art.x86_64
psa-proftpd-xinetd is obsoleted by (installed) psa-proftpd-1.3.4a-suse12.1.build110120606.18.x86_64
Please help.
Code:
# To have more informations about Proftpd configuration
# look at : http://www.proftpd.org/
# This is a basic ProFTPD configuration file (rename it to
# 'proftpd.conf' for actual use. It establishes a single server
# and a single anonymous login. It assumes that you have a user/group
# "nobody" and "ftp" for normal operation and anon.
ServerName "ProFTPD"
#ServerType standalone
ServerType inetd
DefaultServer on
<Global>
DefaultRoot ~ psacln
AllowOverwrite on
</Global>
DefaultTransferMode binary
UseFtpUsers on
TimesGMT off
SetEnv TZ :/etc/localtime
# Port 21 is the standard FTP port.
Port 21
# Umask 022 is a good standard umask to prevent new dirs and files
# from being group and world writable.
Umask 022
# To prevent DoS attacks, set the maximum number of child processes
# to 30. If you need to allow more than 30 concurrent connections
# at once, simply increase this value. Note that this ONLY works
# in standalone mode, in inetd mode you should use an inetd server
# that allows you to limit maximum number of processes per service
# (such as xinetd)
MaxInstances 30
#Following part of this config file were generate by PSA automatically
#Any changes in this part will be overwritten by next manipulation
#with Anonymous FTP feature in PSA control panel.
#Include directive should point to place where FTP Virtual Hosts configurations
#preserved
ScoreboardFile /usr/local/psa/var/run/scoreboard
# Primary log file mest be outside of system logrotate province
TransferLog /usr/local/psa/var/log/xferlog
#Change default group for new files and directories in vhosts dir to psacln
<Directory /srv/www/vhosts>
GroupOwner psacln
</Directory>
# Enable PAM authentication
AuthPAM on
AuthPAMConfig proftpd
IdentLookups off
UseReverseDNS off
AuthGroupFile /etc/group
Include /etc/proftpd.include
Yours
