I am running Plesk 12
Centos 6.5
I have Plesk Firewall Installed.
After the Plesk Firewall was enabled the FTP Stopped working in passive Mode.
I searched the net and found the following :
It started working.
I changed the default FTP port from proftpd.conf
and /etc/services
I allowed the new port in Plesk Firewall in Incoming connection and disabled port 21
Now I am not able to connect to the ftp, I get the following error. Have I missed anything ?
Centos 6.5
Code:
/etc/sysconfig/iptables-config and change the line with IPTABLES_MODULES to: IPTABLES_MODULES="ip_conntrack_ftp"
Code:
port 2392
and /etc/services
Code:
ftp 2392/tcp
ftp 2392/udp fsp fspd
Code:
Response: 257 "/" is the current directory
Command: TYPE I
Response: 200 Type set to I
Command: PASV
Response: 227 Entering Passive Mode (85,25,51,34,216,46).
Command: MLSD
Error: Connection timed out
Error: Failed to retrieve directory listing
