General quota problems
N
npavlidis
Ok lets see....
System: Centos 4.3(installed) updated to current with Plesk 8.01 all updates
Problem 1.
All the traffic the server gets seems to be going to one domain only! astats is showing totaly different things! and plesk-stat is not even opening!
Problem 2.
Disk quotas are totaly ***** the panel says 116MB total but is I check THROUGH the panel manager the size of httpdocs it comes out 169MB and with a limit at 500 proftpd can not upload any files!
Please help :(
First of all what is your virtualization system VZ or other sollution ?
Problem 2.
what do you mean by the panel says 116MB total ? The file manager ? Do you have huge logs ?
Re:
If you are refering to the hosting type its VR
If you are talking about the server itself its a dedicated server.
From term:
20K anon_ftp
4.0K bin
4.0K cgi-bin
16K conf
24K error_docs
170M httpdocs
2.1M httpsdocs
4.0K pd
8.0K private
57M statistics
4.0K subdomains
4.0K web_users
but in the Domains Home it says:
Resource Used Allowed
Validity period Sept 25, 2006 May 1, 2007
Disk space 118 MB 500 MB
Traffic 632 MB/Month 10.0 GB/Month
might it be confusing traffic with disk space???!? i dont know :/ but that sure thing is that you cant upload anything...
