• Dear Pleskians! The Plesk Forum will be undergoing scheduled maintenance on Monday, 7th of July, at 9:00 AM UTC. The expected maintenance window is 2 hours.
    Thank you in advance for your patience and understanding on the matter.
Help adding subdomain DNS entry with an UNDERSCORE
S
ssslude
Hi all im trying to add a DNS entry which starts with a underscore _
ie _name.domain.com
so then I can add the entry test._name.domain.com
when I use plesk 8.2 to add the entry it says its an invalid character although if I add the entry on my windows 2003 DNS server it works fine any suggestions or work around ?
Thanks
A underscore is valid at the start of a host name as per my above example.
I have configured a windows DNS 2003 to support a underscore at the start of a host name for a sub domain but not plesk on linux .. that’s my problem.
Thanks
