horde and roundcube login problem
this is log of mail server, here it seems all right
Jul 3 11:54:27 vps2p courier-imapd: Connection, ip=[::ffff:127.0.0.1]
Jul 3 11:54:27 vps2p courier-authdaemon: received auth request, service=imap, authtype=login
Jul 3 11:54:27 vps2p courier-authdaemon: authpsa: trying this module
Jul 3 11:54:27 vps2p courier-authdaemon: authpsa: authentication request with service='imap' authtype='login' authdata='[email protected].'
Jul 3 11:54:27 vps2p courier-authdaemon: authpsa: auth_psa_common(user='[email protected]', pass='passwordxxx')
Jul 3 11:54:27 vps2p courier-authdaemon: authpsa: password for '[email protected]' is plain 'passwordxxx'
Jul 3 11:54:27 vps2p courier-authdaemon: authpsa: sysusername=popuser, sysuserid=110, sysgroupid=31, homedir=/var/qmail/mailnames/domainname.it/user, [email protected], fullname=<null>, maildir=<null>, quota=<null>, options=<null>
Jul 3 11:54:27 vps2p courier-authdaemon: authpsa: clearpasswd=passwordxxx, passwd=<null>
Jul 3 11:54:27 vps2p courier-authdaemon: authpsa: about to check auth.clearpasswd: pass='passwordxxx' auth.clearpasswd='passwordxxx'
Jul 3 11:54:27 vps2p courier-authdaemon: Authenticated: sysusername=popuser, sysuserid=110, sysgroupid=31, homedir=/var/qmail/mailnames/domainname.it/user, [email protected], fullname=<null>, maildir=<null>, quota=<null>, options=<null>
Jul 3 11:54:27 vps2p courier-authdaemon: Authenticated: clearpasswd=passwordxxx, passwd=<null>
Jul 3 11:54:27 vps2p courier-authdaemon: authpsa: auth_psa_common() callback returned 0
Jul 3 11:54:27 vps2p courier-imapd: LOGIN, [email protected], ip=[::ffff:127.0.0.1], port=[43027], protocol=IMAP
Jul 3 11:54:27 vps2p courier-imapd: LOGOUT, [email protected], ip=[::ffff:127.0.0.1], headers=0, body=0, rcvd=24, sent=286, time=0, starttls=1
I have horde and roundcube, the problem is on both
this is roundcube php error
[03-Jul-2014 15:43:26 UTC] PHP Warning: date_default_timezone_get(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in /usr/share/psa-roundcube/program/lib/Roundcube/rcube_config.php on line 435
[03-Jul-2014 15:43:26 UTC] PHP Warning: session_write_close(): Failed to write session data (user). Please verify that the current setting of session.save_path is correct (/var/lib/php/session) in /usr/share/psa-roundcube/program/include/rcmail.php on line 794
