• Plesk Uservoice will be deprecated by October. Moving forward, all product feature requests and improvement suggestions will be managed through our new platform Plesk Productboard.
    To continue sharing your ideas and feedback, please visit features.plesk.com
How do I run script using sudo from plesk environament
N
next-step
Hi everyone
I need idea/approach to implement following:
php script is working under plesk's apache so it is launched under 'psaadm' user.
Goal: I need to be able to create files in domain /conf/ and domain /var/ folders.
so I need my php script runs shell commands using root access.
both commands below is not working:
exec("mkdir /var/www/vhosts/domain.com/var/newfolder");
exec("sudo -u root -p XXX mkdir /var/www/vhosts/domain.com/var/newfolder");
of course that will work if I do chmod or chown for var folder.
but what is correct approach, anybody can help me???
I found some info but dont know how to use it:
C Utilities Implementing Module Management
As in the main Plesk system, for managing a service you may need to be able to perform actions under a root user. In this case you will need to use the mechanism of setuid utilities, the utilities which in the process of their implementation temporarily change a value of the user with the permissions of which they are executed to the root user.
Note: In order not to make all the utilities setuid root, has been written a special wrapper. Symlinks in <PRODUCT_ROOT_D>/admin/bin/modules/<module_name> should point to ../../../sbin/mod_wrapper, which looks at its argv[0] and runs the appropriate binary from <PRODUCT_ROOT_D>/admin/sbin/modules/<module_name>. That binary need not be setuid root itself, because mod_wrapper is setuid root.
These utilities are called in by selecting a corresponding action in the user web interface and represent the call in of an external program from a control PHP script. Thus control PHP scripts implement a convenient administration interface, while C utilities perform low-level tasks (see example).
These utilities should be contained in the <PRODUCT_ROOT_D>/admin/sbin/modules/<module name>/ directory.
anybody can help here?
I have created my script:
admin/sbin/modules/mymodule/myscript.sh
And link to this at
admin/bin/modules/mymodule/myscript.sh
php script runs it
exec("/usr/local/psa/admin/bin/modules/mymodule/myscript.sh")
but it says "Exec format error"
where Im wrong here?
Why can't you just suid your scripts? Plesk uses SUID wrapper to elevate privileges of the backend utilities.
good point. thank you
now I think that the key for my problem - I cant get my suid working on the server:
PHP:
[root@fjz htdocs]# ls -l /var/www/vhosts/domain.ru/httpdocs/mkdir.sh
-rwsr-sr-x  1 root psacln 263 Oct 10 13:11 /var/www/vhosts/domain.ru/httpdocs/mkdir.sh
[root@fjz htdocs]# cat /var/www/vhosts/domain.ru/httpdocs/mkdir.sh
#!/bin/sh -b
whoami
pwd
mkdir /var/www/vhosts/domain.ru/conf/test
cd /var/www/vhosts/domain.ru/conf/
ls
then logged in as psa client and do:
PHP:
[domainuser@fjz ~/httpdocs]$ ./mkdir.sh
domainuser
mkdir: cannot create directory `/var/www/vhosts/domain.ru/conf/test': Permission denied
./mkdir.sh: line 5: cd: /var/www/vhosts/domain.ru/conf/: Permission denied
css  favicon.ico  img  index.html  mkdir.sh  picture_library  plesk-stat  test
It's a modern Linux feature AFAIK - it accepts suid bits only on ELF binary files.
So, you may:
1. make a binary version of your utility
2. use a hack to utilize ready-made Plesk's wrapper, which elevates privileges of script:
# cp script.sh /usr/local/psa/admin/sbin
# ln -s /usr/local/psa/admin/sbin/wrapper /usr/local/psa/admin/bin/script.sh
# chmod 755 /usr/local/psa/admin/sbin/script.sh
then call /usr/local/psa/admin/bin/script.sh from within your php code - it should be executed as root:root
yes thanks you a lot.
Ive tried to make own suid binary and its fine
Im newbie on this, trying to remember C.
