Question How to add nginx conf for using it with uwsgi for a subdomain or domain?
Fabyc
Hi everyone,
I would like to know how can I set this Nginx conf [1] from Plesk? I tried to add it from Nginx section on a domain or subdomain but I get error when I want to save it.
I have running uWSGI server listening in port 8585 for a pyhon app, but I need to serve with Nginx all the static files.
In case the configuration bellow is not correct, can you suggest me the correct one for add it into Nginx section from Plesk?
[1]
server {
listen 80;
# root folder for static files
root /var/www/vhosts/subdomain.mydomain.com/;
# Add index.php to the list if you are using PHP
index index.html index.htm index.nginx-debian.html;
server_name _;
client_max_body_size 50M;
location / {
include uwsgi_params;
if ($request_method = POST) {
uwsgi_pass localhost:8585;
break;
# First attempt to serve request as file, then
# as directory, then fall back to displaying a 404.
try_files $uri $uri/ =404;
Thanks in advanced
