    CentOS2Alma discussion
Issue HSTS issue with www forward
klowet
Basic Pleskian
Debian 11
18.0.46
Hi
I have a question / problem with the SSL-IT HSTS implementation. When I test the hosted websites on ssllabs.com, then the result is that HSTS is not configured and OCSP stapling is not active. When I test on hstpreload.org, I get two errors:
Code:
Error: No HSTS header
Response error: No HSTS header is present on the response.
Error: HTTP redirects to www first
`http://example.com` (HTTP) should immediately redirect to `https://example.com` (HTTPS) before adding the www subdomain. Right now, the first redirect is to `https://www.example.com`. The extra redirect is required to ensure that any browser which supports HSTS will record the HSTS entry for the top level domain, not just the subdomain.
Please check your domain with the following command:
Code:
# curl -s -D- https://domain.com | grep -i Strict
strict-transport-security: max-age=63072000; includeSubDomains
If you see the same output, that means HSTS is really enabled for your domain.
There is no output.
Without strict: 301 Moved Permanently. And a location header to forward to the domain including www.
