httpd start problem
N
NightStorm
My httpd was running fine with 7.5.1... tried the upgrade to 7.5.2, and now httpd will not start.
Returns the error:
Starting httpd: httpd: bad user name USER
Can't find any documentation for this anywhere... any ideas what I might be looking for?
System is RHES3
httpd version: 2.0.46-44.ent.WB1
I was having the same problem, no httpd starts.
i went to php.ini, commented the ioncube loader line.
tryed to start httpd, no luck.
then i noticed that in
"/etc/php.d" is a file called "ioncube.ini"
i decided to try, commented that line inside of it. saved and exit the file, and restarted apache, it did start.
as i wanted the ioncube to load, i went again to php.ini, removed the comment from the ioncube loader line(it should be at the whole top of the zend section), saved and exit the file (php.ini)
and restarted apache "service httpd restart" and it started wonderfully.
hope this helps you,
best regards,
My zend section on php.ini:
[Zend]
zend_optimizer.optimization_level=15
zend_extension_manager.optimizer=/usr/local/Zend/lib/Optimizer-2.5.7
zend_extension_manager.optimizer_ts=/usr/local/Zend/lib/Optimizer_TS-2.5.7
zend_extension=/usr/local/Zend/lib/ZendExtensionManager.so
zend_extension_ts=/usr/local/Zend/lib/ZendExtensionManager_TS.so
So I don't even have mention of ioncube. Am I supposed to?
This wasn't a problem with 7.5.2, so what did they change?
My directory structure for /etc/php.d is:
imap.ini ldap.ini mbstring.ini mcrypt.ini mhash.ini mysql.ini odbc.ini pgsql.ini snmp.ini xmlrpc.ini
I managed to get httpd to start by creating the user USER with the ame permissions and flags as apache... but I want someone from Plesk to tell me what the Hell I just had to do, and why.
What has changed that suddenly required the user "USER", and why did the install not create it automatically?
Well i had a user that his domains did not worked with www. but did without, so i looked into his /conf/httpd.conf file and it seem it something was wrong there, it complained, so i copied a httpd.conf from a working directory and replaced the domain so it works with the current one. Now apache says the same thing.
httpd: httpd: bad user USER
How can i fix this?
thank you SW-Soft for making a Knowledgebase article about this:
http://kb.swsoft.com/article_41_1520_en.html
The complexity is php.ini does not include the ioncube directive on my Fedora Core 6 box, instead it's included by way of php.d in another folder. I renamed that file (because it had only the ioncube line) and moved the text into php.ini above the Zend code...
