Resolved Huge problem - removed plesk dependencies
tastidk
I mistakenly removed all dependencies for my plesk when updating mariadb from 5.5 to 10.0.
see logs here.
Removed:
mariadb.x86_64 3:5.5.60-1.el7_5.cloudlinux mariadb-libs.x86_64 3:5.5.60-1.el7_5.cloudlinux
mariadb-server.x86_64 3:5.5.60-1.el7_5.cloudlinux
Dependency Removed:
MySQL-python.x86_64 0:1.2.5-1.el7
git.x86_64 0:1.8.3.1-20.el7
lvemanager.noarch 0:4.0-26.13.el7.cloudlinux.1
perl-DBD-MySQL.x86_64 0:4.023-6.el7
perl-Git.noarch 0:1.8.3.1-20.el7
php-mysql.x86_64 0:5.4.16-46.el7.cloudlinux
plesk-base.x86_64 0:17.8.11-cos7.build1708180301.19
plesk-completion.noarch 0:17.8.11-cos7.build1708180322.11
plesk-config-troubleshooter.x86_64 0:17.8.11-cos7.build1708181025.16
plesk-core.x86_64 0:17.8.11-cos7.build1708180301.19
plesk-dovecot.x86_64 0:2.3.0.1-centos7.18031218
plesk-dovecot-imap-driver.x86_64 0:17.8.11-cos7.build1708180920.19
plesk-dovecot-pigeonhole.x86_64 0:0.5.0.1-centos7.18031218
plesk-ext-catalog.noarch 0:1.1.0-148.18030120
plesk-ext-rest-api.noarch 0:1.0.0-32.18030120
plesk-git-http.x86_64 0:17.8.7-cos7.build1708171004.18
plesk-l10n.noarch 0:17.8.11-cos7.build1708181025.13
plesk-mail-pc-driver.x86_64 0:17.8.11-cos7.build1708180927.12
plesk-management-node.x86_64 0:17.8.11-cos7.build1708180301.19
plesk-mysql-server.x86_64 0:17.8.11-cos7.build1708180301.19
plesk-repair-kit.noarch 0:17.8.11-cos7.build1708180516.08
plesk-resctrl.x86_64 0:17.8.11-cos7.build1708180301.19
plesk-roundcube.noarch 0:1.3.6-cos7.build1708180427.13
plesk-service-node-utilities.x86_64 0:17.8.11-cos7.build1708180515.22
plesk-web-hosting.x86_64 0:17.8.11-cos7.build1708180301.19
plesk-wp-upgrade.noarch 0:1.0-71.17091819
postfix.x86_64 2:2.10.1-7.el7
pp17.8.11-bootstrapper.x86_64 0:17.8.11-cos7.build1708180920.15
psa-libpam-plesk.x86_64 0:17.8.11-cos7.build1708180301.19
psa-libxml-proxy.x86_64 0:2.9.7-centos7.18021314
psa-locale-base-en-US.noarch 0:17.8.11-cos7.build1708181211.16
psa-logrotate.x86_64 0:3.8.2-cos7.build1708171004.18
psa-mail-driver-common.x86_64 0:17.8.11-cos7.build1708181205.20
psa-php5-configurator.x86_64 0:1.7.0-cos7.build1708180301.20
psa-phpfpm-configurator.x86_64 0:1.0.0-cos7.build1708180212.17
psa-phpmyadmin.noarch 0:4.8.4-cos7.build1708181212.18
psa-proftpd.x86_64 0:1.3.6-cos7.build1708180220.17
psa-pylibplesk.x86_64 0:17.8.11-cos7.build1708180301.19
psa-updates.noarch 0:17.8.11-cos7.build1708180326.13
psa-vhost.noarch 0:17.8.11-cos7.build1708180425.13
Complete!
how to fix?
Notice plesk is completely removed somehow, so no repair function
Worked like a charm. Thanks, However my phpmyadmin is pretty messed up, and i can't enter the database through phpmyadmin at all. How do i reconfigure phpmyadmin so i can use it again. This is the error i get.
SELECT `comment`
FROM `phpmyadmin_b1wSNw_2PEJi`.`pma_column_info`
WHERE db_name = 'pia_sign'
AND table_name = ''
AND column_name = '(db_comment)'
MySQL returnerede:
#1142 - SELECT command denied to user 'pma_9oeqncPlpJ9v'@'localhost' for table 'pma_column_info'
Guess it's the phpmyadmin root psw not working?
