Issue ImageMagick dependancy problem
tkalfaoglu
Silver Pleskian
AlmaLinux
Obsidian
Hi there.. I can't do a yum update because of dependancy problems.. How shall I proceed?
PS: Shortening it for the forums 10k limit..
Here is what I did so far:
Code:
# yum update
Last metadata expiration check: 3:14:37 ago on Thu 23 Jun 2022 01:09:34 PM +03.
Error:
Problem 1: package plesk-php71-imagick-3.4.3-1centos.8.211108.1944.x86_64 requires libMagickCore-6.Q16.so.6()(64bit), but none of the providers
can be installed
- package plesk-php71-imagick-3.4.3-1centos.8.211108.1944.x86_64 requires libMagickWand-6.Q16.so.6()(64bit), but none of the providers can be
installed
- cannot install both ImageMagick-libs-6.9.12.50-2.el8.x86_64 and ImageMagick-libs-6.9.10.86-1.el8.x86_64
- cannot install both ImageMagick-libs-6.9.10.86-1.el8.x86_64 and ImageMagick-libs-6.9.12.50-2.el8.x86_64
- cannot install the best update candidate for package plesk-php71-imagick-3.4.3-1centos.8.211108.1944.x86_64
- cannot install the best update candidate for package ImageMagick-libs-6.9.10.86-1.el8.x86_64
Problem 2: package plesk-php81-imagick-3.7.0.1-0redhat.8.220610.1010.x86_64 requires libMagickCore-6.Q16.so.6()(64bit), but none of the provide
rs can be installed
- package plesk-php81-imagick-3.7.0.1-0redhat.8.220610.1010.x86_64 requires libMagickWand-6.Q16.so.6()(64bit), but none of the providers can b
e installed
- package ImageMagick-6.9.12.50-2.el8.x86_64 requires libMagickCore-6.Q16.so.7()(64bit), but none of the providers can be installed
- package ImageMagick-6.9.12.50-2.el8.x86_64 requires libMagickWand-6.Q16.so.7()(64bit), but none of the providers can be installed
- package ImageMagick-6.9.12.50-2.el8.x86_64 requires ImageMagick-libs(x86-64) = 6.9.12.50-2.el8, but none of the providers can be installed
- cannot install the best update candidate for package plesk-php81-imagick-3.7.0.1-0redhat.8.220610.1010.x86_64
- cannot install the best update candidate for package ImageMagick-6.9.10.86-1.el8.x86_64
Problem 3: package plesk-php80-imagick-3.7.0.1-0redhat.8.220610.1010.x86_64 requires libMagickCore-6.Q16.so.6()(64bit), but none of the provide
rs can be installed
- package plesk-php80-imagick-3.7.0.1-0redhat.8.220610.1010.x86_64 requires libMagickWand-6.Q16.so.6()(64bit), but none of the providers can b
e installed
- package ImageMagick-devel-6.9.12.50-2.el8.x86_64 requires libMagickCore-6.Q16.so.7()(64bit), but none of the providers can be installed
- package ImageMagick-devel-6.9.12.50-2.el8.x86_64 requires libMagickWand-6.Q16.so.7()(64bit), but none of the providers can be installed
- package ImageMagick-devel-6.9.12.50-2.el8.x86_64 requires ImageMagick-libs(x86-64) = 6.9.12.50-2.el8, but none of the providers can be insta
lled
- cannot install the best update candidate for package plesk-php80-imagick-3.7.0.1-0redhat.8.220610.1010.x86_64
- cannot install the best update candidate for package ImageMagick-devel-6.9.10.86-1.el8.x86_64
(try to add '--allowerasing' to command line to replace conflicting packages or '--skip-broken' to skip uninstallable packages or '--nobest' to
use not only best candidate packages)
[root@storm mysql]# yum remove ImageMagick-devel
Erasing          : plesk-gems-pre-0.0.1-2.redhat.8+p18.0.42.0+t220211.2259.noarch                                                         1/2
Erasing          : ImageMagick-devel-6.9.10.86-1.el8.x86_64        2/2
Removed:
ImageMagick-devel-6.9.10.86-1.el8.x86_64                    plesk-gems-pre-0.0.1-2.redhat.8+p18.0.42.0+t220211.2259.noarch
and also:
Removed:
Complete!
[root@storm mysql]# yum install plesk-gems-pre
Last metadata expiration check: 3:15:30 ago on Thu 23 Jun 2022 01:09:34 PM +03.
No match for argument: plesk-gems-pre
Error: Unable to find a match: plesk-gems-pre
[root@storm mysql]# yum update
Last metadata expiration check: 3:15:43 ago on Thu 23 Jun 2022 01:09:34 PM +03.
Error:
Problem: package plesk-php71-imagick-3.4.3-1centos.8.211108.1944.x86_64 requires libMagickCore-6.Q16.so.6()(64bit), but none of the providers c
an be installed
installed
[root@storm mysql]# yum update --allowerasing
Last metadata expiration check: 3:16:03 ago on Thu 23 Jun 2022 01:09:34 PM +03.
Dependencies resolved.
Package                             Architecture           Version                                       Repository                       Size
Upgrading:
ImageMagick-libs                    x86_64                 6.9.12.50-2.el8                               epel                            2.3 M
Removing dependent packages:
plesk-php71-imagick                 x86_64                 3.4.3-1centos.8.211108.1944                   @PLESK_17_PHP71                 515 k
plesk-php72-imagick                 x86_64                 3.4.4-1centos.8.211108.1944                   @PLESK_17_PHP72                 519 k
plesk-php73-imagick                 x86_64                 3.6.0-1centos.8.211118.1928                   @PLESK_17_PHP73                 513 k
plesk-php74-imagick                 x86_64                 3.7.0-0redhat.8.220616.1430                   @PLESK_17_PHP74                 454 k
plesk-php80-imagick                 x86_64                 3.7.0.1-0redhat.8.220610.1010                 @PLESK_17_PHP80                 462 k
plesk-php81-imagick                 x86_64                 3.7.0.1-0redhat.8.220610.1010                 @PLESK_17_PHP81                 462 k
Transaction Summary
Upgrade  1 Package
Remove   6 Packages
Total download size: 2.3 M
Is this ok [y/N]: n
Operation aborted.
[root@storm mysql]# yum install ImageMagick
Last metadata expiration check: 3:16:26 ago on Thu 23 Jun 2022 01:09:34 PM +03.
Error:
Problem: problem with installed package plesk-php71-imagick-3.4.3-1centos.8.211108.1944.x86_64
- package plesk-php71-imagick-3.4.3-1centos.8.211108.1944.x86_64 requires libMagickCore-6.Q16.so.6()(64bit), but none of the providers can be
installed
installed
- cannot install the best candidate for the job
[root@storm mysql]# yum install ImageMagick --skip-broken
Last metadata expiration check: 3:16:38 ago on Thu 23 Jun 2022 01:09:34 PM +03.
Nothing to do.
Complete!
Same problem here, what should we do?
Code:
# dnf update
Last metadata expiration check: 2:31:35 ago on Fri 24 Jun 2022 07:28:50 AM CEST.
Error:
 Problem: package plesk-php74-imagick-3.7.0-0redhat.8.220616.1430.x86_64 requires libMagickCore-6.Q16.so.6()(64bit), but none of the providers can be installed
  - package plesk-php74-imagick-3.7.0-0redhat.8.220616.1430.x86_64 requires libMagickWand-6.Q16.so.6()(64bit), but none of the providers can be installed
  - cannot install the best update candidate for package plesk-php74-imagick-3.7.0-0redhat.8.220616.1430.x86_64
(try to add '--allowerasing' to command line to replace conflicting packages or '--skip-broken' to skip uninstallable packages or '--nobest' to use not only best candidate packages)
AlmaLinux release 8.6 (Sky Tiger)
