Installation problem - product version selection
L
louis_coetzee
hi, I just purchased my licence key, this is my first time trying to install plesk panel. Please check my steps and see if I am doing something wrong, or if not the case, please help me.
CentOS release 6.3 final x86_64 - minimal
SELINUX = disabled
Firewall = disabled
downloaded autoinstaller from: http://download1.parallels.com/Ples...ler_v3.12.0_build120601.16_os_CentOS_6_x86_64
Did chmod 777 on installer
./parallels_installer_v3.12.0_build120601.16_os_CentOS_6_x86_64
Installation starts:
Current settings:
Install products from Parallels server
Install required system packages from Parallels server
Store downloaded files in: /root/parallels
downloads files....no errors
AND then:
The following product versions are available:
1. [ ] Parallels Plesk Panel
It does not give me a list of versions to select from.
It has now taken me 2 hours of searching, and this is where I am now.
Please help me....
Thanks in advance.
Louis
What list of versions do you mean?
It is latest version of autoinstaller for Plesk 11.
CentOS 6.3 is not officially supported yet. Wait a bit.
Oh, and I'm sure you didn't forget to press '1' and 'Enter' on the screen you posted, did you?
