• Plesk Uservoice will be deprecated by October. Moving forward, all product feature requests and improvement suggestions will be managed through our new platform Plesk Productboard.
    To continue sharing your ideas and feedback, please visit features.plesk.com
Installing Dotnetnuke and running under sql
P
PsYcHoTi
I have setup a dnn site on the server not using plesk and it runs fine, but when i try installing dnn under plesk it will not work.Any help would be greatly appreciated.
Here are the errors im getting.
http://www.bingocharities.com/default.aspx
Server Application Unavailable
or
DotNetNuke Configuration Error
[MESSAGE]
Using Windows Explorer, browse to the root folder of the website ( C:\DotNetNuke by default ). Right-click the folder and select Sharing and Security from the popup menu ( please note that if you are using Windows XP you may need to Enable Simple File Sharing before these options are displayed ). Select the Security tab. Add the appropriate User Account and set the Permissions.
If using Windows 2003 - IIS6
- the NT AUTHORITY\NETWORK SERVICE User Account must have Read, Write, and Change Control of the virtual root of your website
I really need to have some kind of help on this.. i think its a permissions problem but have no idea how to fix it in plesk
I have figured it out..if anyone needs help with this contact me
I have this same issue, please help !!!
Hi, I see you solved the problem. Hope you can tell me how to do it.
Thanx
PsYcHoTi > I have figured it out..if anyone needs help with this contact me.
I need help in this matter.
Just make sure IUSR have Modified permissions, also NETWORK SERVICE.
The ASP.NET user need to have full permissions.
