Resolved Lightsail AWS - problem installation Clonng 95%
RobertQ
Hi, today I have a small question about installation Plesk Onyx on Amazon Lighstail
how long wait installation after launched Initializing.
Now status is Cloning [95%] and nothing happened
I use 8GB RAM and 2 cores processor 80GB SSD
Thank You
Need more details from installation log /tmp/autoinstaller3.log
Hello RobertQ,
I have checked deploy Plesk on Lightsail (my configuration was 1 GB RAM, 1 vCPU, 30 GB SSD) and deploy process took 6 minutes.
I suggest checking /var/log/plesk/amazon_setup.log and wait messages like
Code:
# tail -f /var/log/plesk/amazon_setup.log
==> [Mon May 21 06:10:17 UTC 2018] Update Plesk
All patches were applied.
Patches were installed successfully.
The changes were applied successfully.
==> [Mon May 21 06:12:56 UTC 2018] Update extensions
==> [Mon May 21 06:13:08 UTC 2018] Update is finished
P.S. Plesk installs latest updates at 95% of cloning.
Hello RobertQ,
Code:
Hi I added my amazon_setup.log and autoinstaller3.log, maybe some could you help me
  • backup.zip
I have checked logs. Did you reboot your instance while cloning not finished, didn't you? I have added my comment near "[AYamshanov comment:]" inside CODE snippet.
Code:
[AYamshanov comment:] Cloning in progress, installation of updates
Preparing to unpack .../mysql-server-5.7_5.7.22-0ubuntu0.16.04.1_amd64.deb ...
Unpacking mysql-server-5.7 (5.7.22-0ubuntu0.16.04.1) over (5.7.21-0ubuntu0.16.04.1) ...
Preparing to unpack .../mysql-server-core-5.7_5.7.22-0ubuntu0.16.04.1_amd64.deb ...
Unpacking mysql-server-core-5.7 (5.7.22-0ubuntu0.16.04.1) over (5.7.21-0ubuntu0.16.04.1) ...
[AYamshanov comment:] Interrupting the update process, no any new messages regarding cloning/update
[AYamshanov comment:] Looks like booting of VM, new mapping between external and internal IP-addresses.
==> [Sun May 20 18:35:21 UTC 2018] Update mapping between public and internal IP addresses in Plesk
===> Map '18.x.y.n' to '172.26.2.26' (on MAC 0e:e4:2e:6a:f5:e6)
SUCCESS: Update '172.26.2.26' completed.
Could you confirm that VM was rebooted by manual? If not, could you please attach "/var/log/syslog" file too?
